PC Peripherals New Ryzen build, no display with Native graphics
maddy_in65
Jul 8, 2008
371
50
117
Pune
I recently purchased new build and my requirement thread is here.
Today i assembled desktop and connected it to new monitor but i was never able to get output to monitor.
I checked all cables for any loose connection,
Gone through Motherboard manual to ensure all connections are correct.
New HDMI cable used that came with monitor, used other spare HDMI cables.
When I power on system, CPU and case fans start working and built-in LED lights of case works.
I used same monitor on old setup and it worked fine.
I tried with VU TV, changed HDMI cable but nothing worked.
I searched online but didnt get specific information related to this issue.
Please can someone help here, My build details are mentioned below
CPU: Ryzen 5 2400G
Motherboard: Gigabyte B450 AORUS M
RAM: Corsair 8GB 3000
M2 SSD: Samsung 860 evo 250gb
HDD: Purple 4TB
PSU: CM 550 (Temp. arrangement from local dealer until he provides Corsair CX650)
Monitor: Benq 27GW2780
Case: NZXT H440
maddy_in65
Jul 8, 2008
371
50
117
Pune
From amd forums : " R5 2400G forces HDMI2.0 - but your screen only supports 1.4"
Try dvi-d cable and see if you get display
Or change VGA output to 1920x1080 in Bios
Thanks. I saw it after i posted a query here.
I wil get a DVI cable from friend and test it today.
Reactions: chetansha
maddy_in65
Jul 8, 2008
371
50
117
Pune
I got DVI cable but didn't realize earlier that monitor don't have DVI port. I will try DVI to HDMI converter, hope this will work.
maddy_in65
Jul 8, 2008
371
50
117
Pune
Tested with another monitor but found the cable is different (Got DVI-D single link) :(
Dealer sent his spare DVI-D (Dual link) today evening. I will test it when I reach home and update.
He also sent Corsair CX650.[DOUBLEPOST=1557233380][/DOUBLEPOST]I tried new DVI cable today but still no display. I checked all cables and connections but it is not worked.
Please can someone help here.
PoBoy
Veteran
Sep 7, 2005
2,154
303
172
Mumbai
OK, this is a long shot.
My test system has a old AMD Athlon II X2 250 processor. I faced the same prob. I have a discrete GPU along with the onboard graphics.
If the BIOS 'Initial Display Output' is set to onboard graphics, I get a blank screen if my monitor is connected to the discrete GPU.
Luckily for me I had both, so I connected my monitor to the onboard graphics, went into BIOS and set the Initial Display as PCIX. Then connected the monitor to the discrete GPU and it worked.
Your system may have PCIX as default.
But then again, why has no one else mentioned this ?
EDIT: my mobo is GIGABYTE also.
maddy_in65
Jul 8, 2008
371
50
117
Pune
An update on this issue, It was SMPS who might have caused these issues (might have not provided enough power).
I replaced SMPS with corsair 650, connected system with DVI port and finally got output to monitor.
I changed Display output to onboard graphics and now new monitor works via HDMI.
However it seems the issues are never ending, I am now unable to install windows 10 on M2 SSD.
M2 SSD is detected on BIOS however it is not showing in installer list. This is the only drive connected at the moment. I have enabled fast boot, disabled CMS but nothing works.
maddy_in65
Jul 8, 2008
371
50
117
Pune
Are you trying to install win 10 via USB ? Then keep the USB stick in usb 2.0 port
Yes via USB, I believe that might have not be issue as installer is working fine but it dont recognize M2 SSD drive. However I I will try with USB 2.0 port
vishalrao
Global Moral Police
Veteran
Nov 10, 2007
4,566
679
202
Pune, India
How did you create the USB installer? Using something like Rufus or the windows media creation tool? If something like Rufus, then ensure you selected the UEFI+GPT (not MBR) mode of writing the ISO and try installing again?
maddy_in65
Jul 8, 2008
371
50
117
Pune
I used Linux mint's in built tool to create bootable image. I can see UEFI USB drive in boot menu. Do i need to use any other tool like etcher for win10.
I tried Linux mint image some time back but unable to install it as well. I get grub menu for live os and installation but when i select any option, nothing works.
vishalrao
Global Moral Police
Veteran
Nov 10, 2007
4,566
679
202
Pune, India
If you can't use Rufus (which is a windows-only thing) then on linux try this "WoeUSB" as a quick google search points to https://itsfoss.com/bootable-windows-usb-linux/ maybe that will make a difference.[DOUBLEPOST=1557486912][/DOUBLEPOST]Also check in BIOS if there is an option which lets you select "AHCI" instead of "Legacy" or anything else in the section where you see the m.2 SSD.
maddy_in65
Jul 8, 2008
371
50
117
Pune
Thank you everyone for support.
I made bootable USB using Rufus and it worked like charm. Finallly installed win 10 and working fine.
