Android Nokia releases Z Launcher, a dynamically changing home screen experience for Android
ayanavish
- binned -
Veteran
Nov 19, 2008
1,998
412
122
Bangalore
Nokia has launched a new home screen replacement for Android. The company claims that Z Launcher will give users the power to access their information and apps in the fastest way possible.
The Android home screen app is able to accomplish this by dynamically changing the most frequently used apps throughout the day. Z Launcher is also able to include your contacts and frequently visited websites into the mix making it a complete and robust experience. This is all done locally and does not require a connection to the internet.
If Z Launcher does not offer the apps you are looking for, you can easily bring them up by accessing a feature called Scribble. Scribble works by just drawing the first letter or two of the app or contact you want to access and instantly brings you to the proper selection. This virtually eliminates the need to tap, scroll, and hunt for the application or contact you are searching for.
Z Launcher is currently in an alpha stage and is available as a special download through an Android browser. Those that want to try the new home screen will have to have a device running Android 4.1 or newer.
Source: https://www.zlauncher.com/blog/2014/06/18/helloworld.html
Home: https://www.zlauncher.com
Download the APK directly from XDA as the invitation for getting the launcher is closed now.
http://forum.xda-developers.com/google-nexus-5/themes-apps/z-launcher-nokia-t2788300
ithehappy
Banned
Aug 3, 2012
478
194
81
32
Too many launchers nowadays, way too many. This is just another launcher which is meaningless to me like the Google Launcher! Still using Nova Prime, and still loving it, and still preferring it over other launchers. The only other launcher which has some potential is Aviate, don't know what's going on with it though.
