Spacescreamer
ex-Mod
*3370#
If u low on battery , and no charger in sight ... then ..
Activate the Nokia instrument reserve battery.
Cell will restart with this reserve and wid a 50% incerase in battery.
Reserve will get charged when u charge ur cell
*3370#
This will Activate Enhanced Full Rate Codec (EFR)
Phone uses the best sound quality but talk time is reduced by abt 5%
#3370#
This will Deactivate Enhanced Full Rate Codec( EFR)
*#30#
Lets you see the private number
*#4720#
Activate Half Rate Codec - Your phone uses a
lower quality sound but you should gain approx 30% more Talk Time
*#4720#
Deactivate Half Rate Codec
*#0000#
Displays your phones software version,
The details wd be given like :
1st Line : Software Version,
2nd Line : Software Release Date,
3rd Line : Compression Type
*#9999#
Phones software v ersion in case the code *#0000# aint workin
*#06# For checking the International Mobile Equipment
Identity Number
#pw+1234567890+1# Provider Lock Status.
(use the "*" button to obtain the "pw" and "+" symbols)
#pw+1234567890+2#
Network Lock Status.
(use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3#
Country Lock Status.
#pw+1234567890+4#
SIM Card Lock Status.
*#147# (for vodafone)
lets you know who called you last
*#1471#
Last call
(Only vodofone)
*#21#
Allows you to check the number that "All Calls" are diverted To
*#2640#
Displays security code in use
*#30#
*#43#
Allows you to check the "Call Waiting" status of your phone.
*#61#
Allows you to check the number that "On No Reply" calls are diverted to
*#62#
Allows you to check the number that "Divert If Unreachable(no service)" calls are diverted to
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646#
Removes operator logo
(for 3310 & 3330 )
*#73#
Reset phone timers and game scores
*#746025625#
Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby
time possible
*#7760#
Manufactures code
*#7780#
Restore factory settings
*#8110#
Software version for the nokia 8110
*#92702689#
(to rember *#WARANTY#)
Displays the following - :
1.Serial Number,
2.Date Made
3.Purchase Date,
4.Date of last repair (0000 for no repairs),
5.Transfer User Data.
To exit this mode -you need to reboot
*#94870345123456789#
Deactivate the PWM-Mem
**21*number#
Turn on "All Calls" diverting to the phone number entered
**61*number#
Turn on "No Reply" diverting to the phone number entered
**67*number#
Turn on "On Busy" diverting to the phone number entered
12345
The default security code
press and hold #
Lets you switch between lines.
*#30#
*3370#
#3370#
*#30#
*#4720#
*#4720#
*#0000#
*#9999#
Identity Number
#pw+1234567890+2#
#pw+1234567890+3#
#pw+1234567890+4#
*#1471#
Last call
(Only vodofone)
*#21#
*#2640#
*#30#
*#43#
*#61#
*#62#
*#67705646#
(for 3310 & 3330 )
*#73#
*#746025625#
time possible
*#7760#
Manufactures code
*#7780#
*#8110#
*#92702689#
1.Serial Number,
2.Date Made
3.Purchase Date,
**21*number#
**61*number#
**67*number#
12345
press and hold #
*#30#
