OC & Modding PC cleaning suggestions
Julian
om nom nom
Veteran
Jul 31, 2008
1,829
718
201
38
Navi Mumbai
When i use a blower i try to keep the fans from spinning. usually just block em with my finger or use a pen or something.
Newgamer66
Member
25
5
6
Cochin
I think that blower is more powerful than u need, use carefully . .also some dust really sticks to ur fan blades that dont go while using blowers. I suggest first cleaning with a paint brush then using a blower
Blackend
Nov 11, 2010
235
100
56
35
I use a similar blower to clean the internals and then clean the fans and other components with a soft cloth manually.
bigb123
Active Member
157
45
41
32
I take everything apart including processor and grab a toothbrush and start scrubbing inch by inch until i'm satisfied. Try it.
