Budget 21-30k pc for browsing and watching youtube
asura
Questions
  1. What is your budget?
    • 25-30k
    • CPU - amd phenom 2 x555
    • Motherboard - msi e75
    • RAM - dynamite 2X2GB
    • Monitor - samsung s22
    • PSU - dhruv 400w
    • Monitor
    • CPU - Intel i3 4150
    • Motherboard - asus b85m g... shoud i go for series 9 motherboard
    • PSU - corsair vs450/vs 550..if 450 is ok for my build then i will mostly go fr it
    • RAM - corsair vengenance 1600 4gb
    • ssd - samsung 840evo 120gb
    • any case with front usb 3
    • Yes, i will add one hdd thats it
    • Mumbai{lamington}
    • Open to online purchase
    • no
    • Browsing
    • youtube
    • Watching HD movies
    • yes motherboard should be from asus or gigabyte... already had bad experience with msi
    • no gaming at all
    1. Gaming - no gaming
    2. Desktop - 1920*1080
    • No
  14. -win 7,8
  15. so guys please tell me which smps, motherboard to be used... and any thing else which will make considerable performance gain
Hi Welcome to forum !
I would suggest following;
Intel i3 4150 ~8000
Asus B85M G ~5600
Kingston HyperX Blue 4GB DDR3 1600MHz ~2750
Seasonic S12II 430 ~4000
Sandisk Extreme II 120GB SSD ~5300
Corsair Spec 01 Cabinet ~3600 or Corsair Carbide 200R ~4000
Total ~30,000
Is your existing hardware dead? because as I see it, your existing hardware is capable of performing the duties that you mentioned. At best you can think of changing the PSU to something like corsair and then adding a dedicated graphics card
Intel i3 4150 ~8000
Asus B85M G ~5600
Total ~30,000
thanks a lot...for solving my problem...i just needed somebody to fine tune the parts and u exactly did that..
sandisk ssd and seasonic smps is not available with the primeabgb.. any other replacement
i will be purchasing the pc in next 2 hrs so if any fast reply will be helpfull
thank u vyral.... purchased my pc
my config
i5-4690k
gigabyte h97m d3h
samsung 120gb 840 evo
cs 550 smps
cooler master force 500 cabinet
corsair vengenance 4gb 1600mhz
costed around 35800 from primeabgb lamington shop
after reaching there increased my budget.... now my pc can do more than browsing and watching video
Congratulations on purchase !
Two queries,
Which SMPS you got ? Can you please provide full model name ?
Did you get 4690k or 4690? Since 4690k with H97 motherboard defies purpose of it being 'K'.
i got corsair vs 550.... got 4690k it was 700 rs costlier than 4690 model(in primeabgb) .... z97 board was costing around 9500 from gigabyte or asus.... already had bad experience with msi mobo so didnt go for any other cheaper mobo... went for this config so that i can also use hackintosh
Right but for overclocking 4690k one needs Z97 motherboard or Asus based H97 mobo. With Gigabyte H97 mobo you can not overclock the processor. If you did not intend to overclock 4690k was not required. :what?:
okk. damn asus h97 was within budget. always thought asus and gigabyte are almost equal.. tonymacx86 influence go for gigabyte if you want to build hackintosh...i should have discussed first about this config... anyway i have to be content with my decision
vyral and techenclave community continue your good job... you people are doing great
