PC for light gaming and multimedia for a 11yr old - 30k
ANP !!!
Am gonna buy the PC tomorrow. Let me know if the config is good enough for a 11yr old kid. Also suggest a shop in Lamington Road where I can pick up all these stuffs.
1. Q: What is your budget?
1. 30k (Strict) +/- 1k
None
None
CPU AthlonII X2 245
Mobo Biostar A785GE
RAM 2GB 800MHz Kingston DDRII RAM
HDD 500 GB WD Blue
GPU Sapphire HD4770 512GB DDR5
Cabinet Zebronics Bijili
PSU Gigabyte Superb 460w
Keyboard & Mouse Logitech Set
ODD LG GH22NS30
Speakers Altec Lansing 2.1 VS4121
LCD Benq G2020HD
adding/upgrading a component in near future. If yes then please mention when and which component
1. Yes, will upgrade the following within 1yr
2. RAM - upto 4GB
3. GPU - within 1 yr.
1. Mumbai - Lamington Road
2. Open to online purchase
1. No
1. Gaming
2. Multimedia (songs and movies)
3. Desktop Processing
1. Do not want to buy Asus product as I heard the after sales service in India is pathetic
1. RACING and games suitable to kids
11. Q: What is your preferred monitor resolution for gaming and normal usage
1. Gaming - 1280x728
2. Desktop - 1440x900
1. No
1. Windows 7 32bit
Better buy a DDRIII mobo instead of a DDRII one. Easy for cheaper RAM upgrades in the future.
TheITWares dealer seems to have a Gigabyte DDRIII 740G mobo for 3-3.3k~ Better go for that one as you will be using a discrete GPU the IGP doesnt matter much. He has a shop in Lammy too. PM him for details. Another shop you can chk out is Prime in Lammy.
www.theitwares.com
www.primeabgb.com
If you are tight on budget also consider getting a Sapphire 512MB GDDR5 ~ 5.1 and save 1k~ This GPU should suffice for a 20" monitor.
http://www.techenclave.com/pc-buying-advice/cheapest-ddr3-mobo-amd-555be-inr-164061.html
Thanks for the reply Darky.
Okay I will go for Gigabyte ma74gmt-s2 and DDR3 ram. ;).
btw what do you mean by
Do you mean 5670 ?? will it be able to play recent games (mostly racing) at medium settings ??
radeon 4770 is good but now go for for 5xxx series due to dx11 support and better fabrication process .....:)
i myself used radeon 4770 n now m getting radeon 5850 as i m getting total refun for my RMAed 4770 :cool2:
CPU - II X3 - 425 - Rs.3650
Mobo - ASUS M4A78LT-M LE - Rs. 4450
RAM - 2 GB DDR3 - Rs. 3000
HDD - Seagate 500 GB - Rs. 2350
GPU - ATI 4670 - Rs. 4600
Cabinet - Gamma - Rs.2100
PSU - Gigabyte 460 W - 2350
Keyboard & Mouse - Microsoft 600 Wired - Rs.750
DVDRW - LiteOn - Rs.1150
Speakers - BXR1221 - Rs. 1000
LCD - Samsung 20" 2033 - Rs.7200
- See if you can go +2600Rs. and get the above.
Thanks Techmind for that config, it looks great.
but I feel it wont be well suited for a 11yr old, specially the tricore, which wont be of much use to him. Dual core is more then enough for his use, also what he needs are smoother graphics (so he doesnt cry again for a faster PC :p), and good speakers for movies.
Is the Samsung any better then Benq 20"er ??
Yup the HD5670. Missed it while editing i guess.:ashamed:
And ya as very little desktop processing is involved and more of a gaming PC put more money into the GPU :) Stick to a AthlonII X2 240/245.
HD4770>HD5670>HD4670. The HD5670 is a perfect choice as it has low idle power and you are getting a 20" monitor only and also its DX11. The HD4770 is powerful and low power consuming too but availability may be an issue.
Also the FSP SAGAII 400w is used in the Gigabyte 460 Superb.(Courtesy: Gannu) So get whichever is cheaper and available. Guess the FSP is Rs.200~ cheaper.
As far as HDD is concerned WD Blue has 5yrs warranty against Seagate's 3yrs and WD also offers pick up service in case of RMA. But the Seagate is faster. I would recommend WD as it would reduce RMA hassles.
The Sammy 2033 is a very good monitor. Also check out the Dell S2009W ~ 6.5k. Chk all three monitor in person if possible before deciding.
Thanks Darky that was of great help :D.
I have decided on a final build, let me know if the prices are alright or not.
CPU AthlonII X2 240 2.8ghz 2900
Mobo Gigabyte ma74gmt-s2 3000
RAM Kingston 2GB (2 x 1GB) 240-Pin DDR3 1333mhz 2700
HDD 500 GB WD Blue 2350
GPU Sapphire HD5670 512GB DDR5 5100
Cabinet CM Elite 310 1500
PSU Gigabyte Superb 460w 2200
Keyboard Logitech Set 700
Mouse
ODD LG GH22NS30 1100
Speakers Altec Lansing 2.1 VS4121 2900
DVD blk Verbatim 50 DVD+R pack x2 1200
LCD BenQ G2020HD 6200
Webcam Logitech Webcam C120 600
32450
One small change. Get a single 2GB DDR3 stick now. Coz the mobo has only 2 DIMM slots. So if u get 2 sticks now then u would have to sell your current stick when upgrading.
Also if Corsair RAM is priced <= Rs.3000 get them as it has a 10 years warranty and much better after sales service.
You getting 100 DVD's. Wow. Gonna backup whole of the 500GB HDD data? :p
Mouse
32450
AS DA said get a 2GB single stick
add 1500 more and get
ASUSTeK Computer Inc.
its a hybrid board which will combine its integrated graphics to GPU graphic and u will get enhanced FPS/performance .... as i see u are building PC for games only
That happens with only low end cards like the HD4350(may be the HD4650) IIRC. I think in HD5xxx it will support only the low end HD5450(may be in HD5570) and wont be implemented for the HD5670 etc... Also you need a 890GX for HD5xxx cards to work in Hybrid CrossfireX mode IIRC.
The performance gain is not worth it for implemeting it in mid-range cards and the hybrid can even affect the card's performance if implemented for a card such as the HD5670.
Also the M4A78LT-M LE has only 760G which only supprts Hybrid CrossfireX with a HD3450 IIRC.
Plz take some time and learn about a technology/hardware before suggesting it to someone. It may not be your intention to mislead but these can mislead ppl. So plz refrain from commenting on something that you lack the proper knowledge.
thanks for the info ... yes my intention was not to mislead but to help him .... any way i am a novice when it comes to hardware for s/w little abv novice :bleh:
Thanks for the help ppl, I finally bought the stuffs
CPU AthlonII X2 240 2.8ghz 5700
RAM Corsair 2GBx1 240-Pin DDR3 1333mhz 2900
HDD 500 GB WD Blue 2250
GPU Sapphire HD5670 512GB DDR5 5575
Cabinet NZXT Gamma 2100
PSU FSP Saga II 400W 2100
Keyboard Microsoft Wired desktop 500 650
Mouse
Speakers Altec Lansing 2.1 VS4121 2800
DVD blk Verbatim 50 DVD pack 575
LCD Samsung 2030SW 6800
I got my stuff from E-Lounge (aka theITwares), Rahul was a nice guy to deal with.
Got the Samsung 2030SW instead of the Benq, cause it was out of stock, and I was somehow hoping for a 2030SW cause my cousin might like the look of it.
Also 2030SW is better then 2033SW, it has more contrast (50000:1 vs 15000:1 dynamic on 2033SW) and an audio jack which is not there on 2033SW and few other things.
Gigabyte Galaxy 460w was not available so I got the FSP which was available for the same price, since these both PSU uses the same circuitry.
When all these stuffs were being ordered, there was NZXT Gamma cabby lying on the shelf, the style really got my eyes, but it was more expensive, but one look into its internals made me think it was worth it. Previously I was thinking for a CM Elite 310.
I was on a very tight budget of 32k, so I tried to trim on the quality a bit, I was previously gonna go for Kingston RAM but it was not available, so got the Corsair, which was 200 more, but it was worth it, cause I really like corsair After sales service.
