Budget 21-30k [Performance PC] Need Entry-Level Gaming PC in 25K.
N5233
Thanks to TE, I assembled my PC 4 Months ago which is Running Extremely Awesome until now! :D Being Impressed by that, One of my friends also wants to assemble his PC. So here is the more info about that!
TiA for your Suggestions!
  1. Q: What is your budget?
    • 25K
    • No Idea. I'll ask my friend and will update it soon.
    • Peripherals like Mouse, KB etc.
    • CPU - i3 or i5. Best that Budget Permits.
    • Mobo - Again, Best that Budget permits.
    • GPU - Same as Above
    • RAM - 4GB
    • Cabinet
    • Monitor - 17"
    • no. this one will be final. No Upgrades soon.
    • Pune
    • No
    • Gaming
    • Browsing
    • HD Movies
    • Home PC
    • No Brand Preference.
    all the latest ones mostly.
  11. Q: What is your preferred monitor resolution for gaming and normal usage
    1. Depends on new monitor.
    • No
    • Windows 7 64 bit
He is Pretty much Tight on Budget. So Please Suggest under 25K. Max 26K.
Hope this info Helps!
Regards~
Nihar
@N5233 Go with this config-Intel i3 3220-7k
Gigabyte B75M D3H-4.5k
Corsair value Ram 4GBX1-1k
Segate 500GB 7200.14-3.7k
Sapphire HD7750-7k
Corsair CX430V2-2.4k
Dell IN2030M-6.2k[20" Monitor]
Nzxt Gamma-2.4k OR Bit fenix Alpha-2.8k
Logitech MK200 Combo-0.7k
If you want to add GPU you'd have to stretch the budget by 5-7k.
Hope this helps.
Sapphire HD7750-7k
Hope this helps.
Umm.... The PC will be used for Gaming and Budget is really tight. Please suggest something with GPU!
I have suggested a GPU in the above rig,You'll be able to game @mid setting with your resolution.Can't go any cheaper than above rig,You'd have to add some more bucks if you want a GPU.You would have to sacrifice Intel i3 with Intel G630-3.2k,That would decrease your performance.
