blackbird
Hi , for a couple of months was on a look out for a good hdtv for my parents room.Had decided to get a plasma after some extensive research , so zeroed it down to the panasonic pv80 and the lg pg61.After some more researching learnt lg handled standard definition better also it was better looking,finally got one a couple weeks back.
The verdict , pic quality rocks big time.Couldnt believe my standard cable could look so good ,even dvds rocked big time along with high def.Sound is ok ok ,looks good switched of too plus it is really really thin.Glass reflection is a pain in the <<<.Damages 52k
Specs : LG 42 pg61
Resolution :1024x768p
Brightness :1500 cd/m²
Contrast Ratio :30,000:1
Response Time :0.001 ms
Scanning :100 hz
View Angle :178/178
Aspect Ratio :16:9 ,Aspect Ratio Correction :7 Modes
(16:9/Just Scan/Auto/4:3/14:9/Zoom1/Zoom2 )
Inputs : 3 [Hdmi 1.3],1 Vga ,1 usb 2.0 , 2 component, 1[ s video, av out]
HDMI input :480i/480p/576i/576p/720p/1080i/1080p
1080p input :HDMI 60p/30p/24p ,Cinema 3:2 / 2:2 Pull down Mode
USB 2.0 : mp3, jpeg , Divx, Xvid, AVI, MPG, MPEG, MPE
Life Span (hr) :100,000Hrs
lg cric.jpg - imgX
Specs : LG 42 pg61
Scanning :100 hz
View Angle :178/178
lg cric.jpg - imgX
