Pranav.Falcon
Hey guys,
Kindly suggest a good configuration with the below details. Thank you in advance.
- What is your budget?
- 30K
- None
- None
- Nothing decided, but will prefer Intel combo with nVidia Graphic card
- Not purchasing Monitor and speakers.
- Final config
- Mumbai
- Open to online purchase
- No
- Gaming
- Browsing
- Watching HD movies
- None
- All Genres
- Gaming - 1280x720
- No
- Windows 7 64 bit
