Budget 90k+ Please suggest PC parts for Lighting and Rendering build
Koncord9
New Member
5
0
1
Hi Everyone,
I am going to built a PC from scratch for my work of Lighting & Rendering. So below i have answered the template questions. Basically my budget is kind of tight Can you please suggest me if there are any changes needed in my built. Anywhere i can reduce or change or save on.
I will be using Software like Maya (Most), Unreal engine, Substance Painter, Adobe Photoshop & Aftereffects, Foundry Nuke & Katana and Renderers like Arnold, Vray, Renderman, Redshift etc.
  1. What is your budget?
    • Around or below 1 Lakh to 1.3 Lakh
    • Building a PC from scratch
    • CPU - Intel Core i7 9700K 3.6 Ghz
    • Motherboard - MSI Z390-A PRO or any other suggestion
    • GPU - Galax GeForce RTX 2070 Super EX (1-Click OC) 8GB GDDR6
    • PSU - CORSAIR VS650 SMPS - 650 Watt or any other if you thought
    • RAM - Corsair (8 x2 )16 GB Vengeance LPX DDR4 3600 Mhz
    • CPU Cooler - COOLER MASTER MASTERLIQUID ML240L RGB or any other suggestion
    • Primary storage - 250-512 GB M.2 / SSD, Please suggest ( brand and price also)
    • Secondary storage - WD or Seagate 1TB HDD
    • Case - Antec Dark Avenger DA601 RGB (E-ATX) Mid Tower or any other suggestion
    • Monitor - I have needed for Color works, atleast 100% sRGB,HDMI, DVI ports, 24inches
    • (please mention the rest in above format)
    • Yes, this is my final configuration unless you guys recommend something else . will upgrade the following maybe after 6-8 months
    • RAM - may be upgrade to 32 GB
    • Secondary storage - will add another TB
    • Mumbai
    • Open to online purchase for few parts
    • No
    • Animation(Lighting and Rendering)
    • GPU rendering
    • Gaming
    • Browsing
    • Sometimes overnight rendering( yes only sometime)
    • Watching HD movies
    • Not really, but i am opting for Intel over AMD for long term goal.
    • GTA 5 and similar
    1. 1920 x 1080
    • Ram , CPU mostly No
    • Windows 10 64 bit
    • Linux - CentOS (might install after few months of use)
bssunilreddy
Veteran
Mar 24, 2007
2,110
825
207
41
Nellore
plus.google.com
AMD Rendering RIG
Budget -130.2K
Processor -AMD Ryzen 7 3800X -33.3k
Motherboard -Asus TUF Gaming X570 Plus-17.2k
Graphics Card -Asus Phoenix RTX 2060 Mini -24k
RAM -G.SKILL Sniper X 16GB (2 x 8GB) DDR4 3600 -7.3k
SSD -Intel 1TB 660P NVMe M.2 Internal SSD -8.4k
Power Supply -Antec Earthwatts Gold Pro 750w -7.4k
Cabinet -Corsair SPEC Delta RGB -5.5k
Monitor -Benq 27 inch EW277HDR -15.5k
KB & Mouse -Cooler Master Masterkeys Lite L Combo -4.1k
UPS -APC 1.1 KVA -5.6k
Fan -Jonsbo FR-601 RGB Fan -.9k
Shipping -1k
Total -130.2k
Koncord9
New Member
5
0
1
thank you guys for your responses, really helped a lot. I will post my updated build list shortly
