Darklord
My Project car
Was purchased back in 1999 and became a standby car by 2005 when it was replaced by Skoda Octavia. Remained as a humble standby car till 2010. Its in March 2010 that I took up this project to have quick Lancer.It had to be a Lancer just because I am so bloody obsessed with it
Here is a basic Modification list -
1) Original 2L Diesel engine (4D68) removed and swapped with 2L Petrol (Cedia,4G94) engine.
2) Entire wiring loom sourced from abroad
3) Diesel gearbox removed and normal petrol lancer gearbox used.(Both are F5M41 but the bell housing is different and so are a few ratios but essentially is the same box, tried both the boxes with petrol lancer bell housing to check which is better in terms of driveability,as of now settled with the Petrol lancer box)
4) Custom strut braces fabricated (Front & Rear)
5) Koni Sport adjustable shock absorbers installed all over (koni Yellows).Retained stock springs for now.
6) Chassis,engine bay strengthening done.
7) TRE 255 LPH Fuel pump installed
8) AEM Adjustable fuel pressure regulator installed
9) 3 angle valve job done
10) Intake and exhaust port matching done
11) Port polishing done
12) 2.5" 4x2x1 Full free flow exhaust done
13) Full Stainless steel custom turbo manifold fabricated
14) Innovate wideband O2 sensor and controller installed
15) Oil Pressure/Oil Temp gauges hooked up
16) Real time AFR monitoring
17) SOHC head swapped with DOHC head from 4G93E engine.
18) Changed OE pistons with Wiseco Forged pistons
19) Changed OE Conrods with K1 forged conrods
20) Switched to ACL & King main and connecting bearings when engine was rebuilt
21) ARP Head studs which can be torqued more than OE studs, necessary for turbocharged engines.
22) Custom made Slotted and Cross drilled brake rotors.
Things in pipeline/in progress
6) Deatschwerks 600cc injectors
7) MHI TD05 16G Hybrid turbo
8) Mishimoto front mount intercooler
9) Lancer GSR Brake kit ( Big brake kit for front and rear disc conversion)
10) DIYPNP standalone engine management (based on Megasquirt open platform)
Click here to view the gallery.
