PureVPN for $1.32/mo on 5 Years Plan - Is it worth it?
vaalkai
Active Member
105
46
41
Rating - 0%
0   0   0
If you are going to use VPN for want of privacy, i would recommend staying away from PureVpn or Nord. If you just want to hide from your ISP then it might be OK. Do a speed test with the services you would use before you commit for 5 years.
skoka123
May 2, 2008
470
135
132
Rating - 100%
3   0   0
So what is the VPN you would suggest for Privacy? Also, is there a VPN that can be configured in the router? I am on Airtel vFiber.
vaalkai
Active Member
105
46
41
Rating - 0%
0   0   0
I would recommend Mullvad. Any VPN provider who uses OpenVpn should be configurable on the router, provided your router model supports it. Basic routers dont.
Mullvad provides both Wireguard and OpenVpn if i remember correctly.
Reactions: nimod
puns
Section Mod
Mar 24, 2005
1,368
401
173
New Delhi
Rating - 100%
14   0   0
You can try limevpn. Singapore based and fast servers. No logs. 1$ a month for basic.
vaalkai
Active Member
105
46
41
Rating - 0%
0   0   0
Lot of VPN sites say they dont keep logs, many have proven to be outright lying or dont mind sharing details about you to the authorities. Any one with basic knowledge can rent a server and set up a VPN server, so there are lot of shady providers.
If you want the cheapest stuff then you can just rent a VPS and install openvn/wireguard or use scripts algo/streisand and get your own vpn running, even share with your friends.
For review of VPN with respect to privacy check https://thatoneprivacysite.net.
vaalkai
Active Member
105
46
41
Rating - 0%
0   0   0
They have done a lot of shady stuff in the past that i wouldn't trust them.
Read the privacy policy, they log connection details
Read more
The more deeper you go, the more you realize almost all are junk, take your time to Google.
You would have to compromise one way or the other, find out why you need VPN for and select a provider accordingly.
Interesting take on this:
