Question for people with Vista SP1 RC installed
KingKrool
Can you tell me which version of ntoskrnl.exe is installed?
To check, navigate to windows\system32\ , right click on the file ntoskrnl.exe, select properties. In the details tab, there should be a version which will look something like 6.0.6000.xxxxx
Can you let me know what the version number is? Thanks.
Also, let me know if this is Vista32 or Vista64 (more interested in 64 bit, but even 32 bit will be helpful :) )
I suspect an OS update to ntoskrnl may have affected my computer in an unsatisfactory way.... but it is difficult to say as I cannot really pinpoint what is going on, and the problem persisted with Windows Server 2008 RC2. I'm hoping that Vista SP1 will cure this issue if the problem is in software.... however I suspect this may be a hardware issue (damned Dell crap @&*!@!##)
