PC Peripherals Router suggestion for RailWire
jaleel_sh
I have been using D-link DWR 116(RailWire broadband) for past two years, from yesterday the Internet not connected, Service people said that the Wan port was not working, they tested with their own router for checking.
Please suggest a good router below 1.5k, to connect pc and smart tv. Initially i thought MI 3c router, but require at least 3 Land ports.
How about TP-Link 841N , that is like the best router in this range with support of dd-wrt/openwrt as well if you look to venture into those someday.
TP-Link routers are very popular amongst users. Go to Flipkart, choose a model that meets your requirement. Get it from wherever you like. iBall too has some low-cost models. As low as 1K and decently interfaced with quick configuration.
PS : Which plan do you use ?
Plan 1100 Rs. (100 GB/20 Mbps, Post FUP 1 Mbps]. But, not satisfied with Railwire. Because speed fluctuates between 5-10 Mbps only, After multiple complaints, there is no improvement.
The main irritation is per day in a week, the cable will cut between lines, the local cable operator fixed after 6-8 hours.
Thinking to move Airtel.
TP-Link routers are very popular amongst users. Go to Flipkart, choose a model that meets your requirement. Get it from wherever you like. iBall too has some low-cost models. As low as 1K and decent interfaced with quick configuration.
