Budget 51-70k Ryzen 5 PC Build; Budget 55K-60K
EHH
New Member
14
0
1
Hi Experts,
My first PC build, kindly suggest / approve.
System 1 is for myself.
System 2 is for my Bro.
Thanks
SYSTEM 1:
  1. What is your budget?
    • 55-60K for CPU
    • Laptop
    • Monitor - Dell 22” FHD
    • Key Board / Mouse
    • Prices from MDComputers
    • R5 3600 Rs.17050
    • B450 DS3H Gigabyte (any suggestion for board with built in Wi-Fi) Rs.6450
    • G.Skill Ripjaws V 16GB (8GBx2) DDR4 3200MHz Rs.8500
    • GPU:
    • Asus RX 580 Dual OC Edition 8GB GDDR5 Graphics Card Rs.17300
    • or
    • SAPPHIRE RADEON RX 580 8GB GDDR5 PULSE OC GRAPHICS CARD Rs.17300 (md comp says OC card but I think its a typo error, there is no OC model afaik)
    • or
    • GIGABYTE GRAPHICS CARD RX 580 8GB GDDR5 GAMING Rs.17500
    • 240 / 480 GB SSD WD Green AND 1 TB or 2 TB HDD Suggestions ?
    • Corsair Spec05 + VS650watt combo (price to be checked at local market)-cheaper option in cabinet will work.
    • Cabinet Fans (avoid RGB, if possible)
    • UPS
    • No upgrade for 5 years.
    • Delhi
    • Open to online purchase
    • Yes (maybe)
    • Coding, running tests, simulations
    • Multiple Excel files updating with real time data from web.
    • Gaming
    • Browsing
    • Desktop Processing
    • Download rig, 24x7 operation
    • Watching HD movies
    • Do not want to buy MSI product as I heard the after sales service in India is pathetic
    • Strategy - Civilization 4
    • Battlefield
    • PUBG
  1. Gaming – 1080p
  2. Desktop – 1080p
  3. TV - 4K
  • Maybe.
  • Windows 10 64 bit
SYSTEM 2:
R5 3400G
Rest parts as above w/o GPU.
Will upgrade CPU/GPU in 3 years.
I am looking to run multi-monitor (3-4 no.) on EACH System.
nac
Feb 5, 2008
517
80
116
Build #1
Go for better board. Around that budget there are two options Asrock B450 Pro4 and B450 Fata1aty Gaming4.
Memory sticks seems little pricey, check other places as well. You can find cheaper options, probably the same model or from other brand with the same specifications.
GTX 1660 is a better option for about the same price or even cheaper.
Go for better SSD than WD Green. Crucial MX500 is a better option.
Avoid VS series and why the need of 650w? Are you gonna go crazy with overclocking. Anyway, depends on your budget you can either go for Corsair CX series or Seasonic S12 II or M12 II.
It's gonna overshoot your budget a bit.
Build#2
DS3H doesn't fit in your criteria. Again the same options as the first build. There are no other boards which fits your criteria of connecting 3 monitors I would suggest unless you want some brand specific models.
Emperor
Jan 12, 2006
3,397
87
137
Visit near by Shop for Quotation (ask them to provide GST Invoice for each & every part you will buy) , you may save more compare to Online.
Also, with online purchase, very little or nil help from seller but offline, GOOD seller can be very very helpful if any issue with h/w
HTH
Reactions: panther
EHH
New Member
14
0
1
Picking up parts for R5 3400G system.
Could not find reccomended Asrock Pro/K4 mobo offline/online.
Kindly suggest any other B450 mobo.
Requirements:
Should run 3 monitors simultaneously.
Should support NVME (Crucial P1).
Dual channel DDR4.
nac
Feb 5, 2008
517
80
116
Earlier this week B450M Pro4 F was available in itdepot. Check if it's still available.
There are roughly a dozen models which support 3 display out. If we rule out the boards which has no VRM heatsink and/or with only two dimm slots, you have roughly handful of models. And most of them are not available. Grab it before it goes out of stock.
bssunilreddy
Veteran
Mar 24, 2007
2,084
810
207
41
Nellore
plus.google.com
Budget -65.2K (GTX1650)
Processor -AMD Ryzen 5 3600 -17k
Motherboard -Asus TUF B450 Plus Gaming-8.6k
Graphics Card -Zotac GTX 1650 4GB Mini -12.8k
RAM -G.Skill SniperX 3600Mhz 16GB(8GBx2) -7.3k
SSD -Intel 660P 512GB NVME M.2 SSD -5.5k
Cabinet -Antec P8 ATX Cabinet -5k
PSU -Antec NE 550M -4k
Total -65.2K
Reactions: mk76
mk76
Dec 4, 2008
836
330
153
Total -65.2K
It is impressive, how diligently bssunilreddy contributes to EVERY PC config request :)
EHH
New Member
14
0
1
Got antec gx202 case, will cx550w fit in it or should I go for an antec psu ?
How is Gigabyte PB 500 80+ Bronze ?
Parts bought till now:
R5 3500
Crucial P1 500gb
Antec gx202
bssunilreddy
Veteran
Mar 24, 2007
2,084
810
207
41
Nellore
plus.google.com
Reactions: EHH
