vip
Sapphire IPC-AM3DD785G is Mini-iTX motherboards designed with rich functionality and reliable performance in a small footprint that measure just 170 x 170 mm. The highly integrated platforms features low power consumption of less than 100 Watts and have one basic PCI-E X16 expansion slot for graphics card. They're ideal platforms for fast-emerging markets in which compact size and power-efficiency are required, such as information station kiosks, POS, lottery machines, gaming systems, factory automation, compact embedded Box IPCs, Wall - mount systems, 2U ~ 4U Rack-mount systems, SBC systems, Digital Signage, and many others.
AMD Phenom â„¢ II AM3 â„¢ Quad-Core Processors with True Quad-Core Technology
1. Smoother faster experience, even when running complex software application with native. Smoother faster experience, even when running complex software application with native.
2. Multi-Core Technology Multi-Core Technology
3. Scaled performance to conserve PC power with HyperTransport® 3.0 Technology Scaled performance to conserve PC power with HyperTransport ® 3.0 Technology
4. Hear your music, not your PC with AMD PowerNow! â„¢ Technology (Cool'n'Quietâ„¢ Technology) Hear your music, not your PC with AMD PowerNow! â„¢ Technology (Cool'n'Quiet â„¢ Technology)
5. Prevent the spread of certain viruses and strengthen your network integrity with Enhanced Virus Protection (EVP) Prevent the spread of certain viruses and strengthen your network integrity with Enhanced Virus Protection (EVP)
6. With DDR3 memory controller to expend memory bandwidth and upgrade higher speed With DDR3 memory controller to expend memory bandwidth and upgrade higher speed
AMDâ„¢ 785G Chipset: Backbone of the Performance Platform AMD â„¢ 785G Chipset: Backbone of the Performance Platform
AMD HD4200 redefine the Way You Play. Enjoy awesome gaming performance for the mainstream PC with stunning visual effects and dynamic interactivity with Microsoft® DirectX® 10.1. ATI Stream technology enables AMD graphics processors, working in concert with AMD Processors, to accelerate many applications beyond just graphics. This enables superior balanced platforms capable of running demanding computing tasks fast. Get a smooth and amazingly visual PC experience for Microsoft® Windows® 7, with support for features such as “Aero Shakeâ€, “Aero Glassâ€, “Transparent Windows†and more! AMD HD4200 redefine the Way You Play. Enjoy awesome gaming performance for the mainstream PC with stunning visual effects and dynamic interactivity with Microsoft ® DirectX ® 10.1. ATI Stream technology enables AMD graphics processors, working in concert with AMD Processors, to accelerate many applications beyond just graphics. This enables superior balanced platforms capable of running demanding computing tasks fast. Get a smooth and amazingly visual PC experience for Microsoft ® Windows ® 7, with support for features such as "Aero Shake", "Aero Glass", "Transparent Windows "and more!
Energy Smart Energy Smart
ATI PowerPlay™ and AMD PowerNow™ 3.0 with Cool n' Quiet™ technologies give you maximum performance when you need it, and save power when you don't, while delivering a superior “Green PC†experience.. ATI PowerPlay ™ and AMD PowerNow ™ 3.0 with Cool n 'Quiet ™ technologies give you maximum performance when you need it, and save power when you don't, while delivering a superior "Green PC" experience ..
ATI Avivoâ„¢ HD ATI Avivo â„¢ HD
1. Dedicated unified video decoder (UVD 2) for H.264/AVC and VC-1 video formats to HD playback of both Blu-ray and HD DVD formats Dedicated unified video decoder (UVD 2) for H.264/AVC and VC-1 video formats to HD playback of both Blu-ray and HD DVD formats
2. Hardware MPEG-1, MPEG-2, and DivX video decode acceleration Hardware MPEG-1, MPEG-2, and DivX video decode acceleration
3. ATI Avivo Video Post Processor to ATI Avivo Video Post Processor to
â– Color space conversion â– Color space conversion
â– Chroma subsampling format conversion â– Chroma subsampling format conversion
â– Horizontal and vertical scaling â– Horizontal and vertical scaling
â– Gamma correction â– Gamma correction
â– Advanced vector adaptive per-pixel de-interlacing â– Advanced vector adaptive per-pixel de-interlacing
â– De-blocking and noise reduction filtering â– De-blocking and noise reduction filtering
â– Detail enhancement â– Detail enhancement
â– Inverse telecine (2:2 and 3:2 pull-down correction) â– Inverse telecine (2:2 and 3:2 pull-down correction)
â– Bad edit correction â– Bad edit correction
OC-CON high-polymer solid electrolysis aluminum capacitors embedded OC-CON high-polymer solid electrolysis aluminum capacitors embedded
The working temperature is from 55 degrees Centigrade below zero to 125 degrees Centigrade, OC_CON capacitors possess superior physical characteristics that can be while reducing the working temperature between 20 degrees Centigrade each time, intact extension 10 times of effective product operation lives, at not rising degrees Centigrade of working temperatures each time a relative one, life of product decline 10% only too. The working temperature is from 55 degrees Centigrade below zero to 125 degrees Centigrade, OC_CON capacitors possess superior physical characteristics that can be while reducing the working temperature between 20 degrees Centigrade each time, intact extension 10 times of effective product operation lives, at not rising degrees Centigrade of working temperatures each time a relative one, life of product decline 10% only too.
CPU
AMD AM3 processor support
Chipset
AMDâ„¢ 785G Chipset + SB710 Chipset AMD â„¢ 785G Chipset + SB710 Chipset
Hyper Transport Bus Hyper Transport Bus
HT 3.0 HT 3.0
Integrated Graphics Processor Integrated Graphics Processor
ATI Radeon HD 4200(Support Microsoft DX 10.1) ATI Radeon HD 4200 (Support Microsoft DX 10.1)
Memory Memory
2 * 240-pin DDR3 DIMM slots 2 * 240-pin DDR3 DIMM slots
Supports DDR3 1333/1066 non-ECC ,un-buffered memory Supports DDR3 1333/1066 non-ECC, un-buffered memory
Max.8GB Max.8GB
Expansion Slots Expansion Slots
1 * PCI Express 2.0 x16 slot @16-lane 1 * PCI Express 2.0 x16 slot @ 16-lane
Storage Storage
Embedded SB710 Chipset Embedded SB710 Chipset
4 * Serial ATA2 3Gb/s connectors 4 * Serial ATA2 3Gb / s connectors
Supports HDDs with RAID 0, 1,10 functions Supports HDDs with RAID 0, 1,10 functions
1 * Ultra DMA 133 / 100 / 66 IDE Connector 1 * Ultra DMA 133 / 100 / 66 IDE Connector
Audio Audio
VIA VT1708S 6-Channel HD Audio CODEC VIA VT1708S 6-Channel HD Audio CODEC
Ethernet LAN Ethernet LAN
Atheros AR8121 PCI-E LAN chip for Gigabit Ethernet LAN Atheros AR8121 PCI-E LAN chip for Gigabit Ethernet LAN
USB USB
Embedded 10 * USB 2.0/1.1 Embedded 10 * USB 2.0/1.1
Special Features Special Features
Advanced Power Design that supports the latest Socket-AM3 CPU Advanced Power Design that supports the latest Socket-AM3 CPU
Support S3 to save power Support S3 to save power
Support CPU Smart Q-FAN Support CPU Smart Q-FAN
6 layer PCB design and long life, high temperature tolerance components used 6 layer PCB design and long life, high temperature tolerance components used
Support TPM by TPM module Support TPM by TPM module
Rear Panel I / O Rear Panel I / O
6 * USB 2.0/1.1 ports 6 * USB 2.0/1.1 ports
1 * VGA port 1 * VGA port
1 * RJ-45 port 1 * RJ-45 port
1 * SPDIF_Out port 1 * SPDIF_Out port
1 * Audio I / O port 1 * Audio I / O port
1 * HDMI port 1 * HDMI port
1 * PS/2 KB/MS port 1 * PS / 2 KB / MS port
Internal I / O Internal I / O
2 * USB 2.0/1.1 headers for 4 USB 2.0/1.1 ports 2 * USB 2.0/1.1 headers for 4 USB 2.0/1.1 ports
1 * 4-pin CPU Fan connector 1 * 4-pin CPU Fan connector
1 * 3-pin Chassis System Fan connectors 1 * 3-pin Chassis System Fan connectors
1 * 4-pin ATX 12V Power connector and 1 * 20-pin ATX Power connector 1 * 4-pin ATX 12V Power connector and 1 * 20-pin ATX Power connector
1 * Front Audio header 1 * Front Audio header
1 * Serial Port header 1 * Serial Port header
1 *SPDIF_Out header 1 * SPDIF_Out header
1 * Front Panel header 1 * Front Panel header
1 * TPM header 1 * TPM header
BIOS BIOS
AMI DIP socket removable flash BIOS EEPROM AMI DIP socket removable flash BIOS EEPROM
Form Factor Form Factor
Micro ATX Form Factor (170X170 mm) Micro ATX Form Factor (170X170 mm)
CPU
Chipset
HT 3.0 HT 3.0
Memory Memory
Max.8GB Max.8GB
Storage Storage
Audio Audio
USB USB
BIOS BIOS
