Jules Goes
Hey guys , My friend wants to setup a system & a budget of Rs 35000. was thinking of the i5 6th 6400 . He will be going for a graphics card later on .
- What is your budget?
- 35k
Non
- CPU - i5 6th 6400
- Yes, will upgrade the following within 6 months
will be adding a graphic card later
- Mumbai
- Open to online purchase
- No
- Photoshop
- Browsing
- Desktop Processing
- Watching HD movies
- no
- Gaming - 1280x720
- Desktop - 1440x900
- no
- Windows 7 64 bit
