Smart bulb Wifi
ashish
215
18
82
Hom3
I'm looking forward to a buy a wifi rgb smart bulb to play with but confused on some factors.
Noob here so excuse for silly questions.
  1. Will it fit in existing holder sockets of regular cfl/led bulbs we got at home? Or do I need to order any connector for this to fit in existing holders.
  2. Via app can we program the bulb to change to a specific color during night and evening?
  3. Also, can we control its luminous intensity? I mean if I buy a 15w bulb can I dim it via the app to illuminate it dimmer at around 3 watt during bed time?
  4. Finally, which brand to go for wrt to service, durability and android app configuration?
ashish
215
18
82
Hom3
Marcus Fenix
Veteran
Nov 22, 2010
1,347
515
152
Kolkata
I got a smart bulb for my bedside lamp.
I needed to install Mi Home app for the initial setup and integration with Alexa and after that I uninstalled Mi Home and have been controlling it with voice commands to my Echo.
Seems pretty expensive but we nerds go for some novelty items sometimes.
P.S. I turn the bedside lamp to 50% brightness with red colour after 11 PM to minimize the blue light effect.
nikhilavasthi
Member
47
90
21
Jogeshwari, Mumbai, Maharashtra
I went through the links and got some basic info.
But none of the brands are avaliable in India. Philips is there but tseems they got only white ones.
I saw this syska ones and very confused as 9w costs too cheap than 7w. I wonder why so?
Wait for any Amazon or Flipkart Shopping Festival (if you can wait and I doubt with current crisis - how they will undertake), you will find better deals with combo offers (either Google Home or Amazon Alexa) and when they sell it as a combo - you have an option to use smart speakers to dim/change light color and so on to control the features via voice only (like what @Marcus Fenix has worked on with his Echo)
ashish
215
18
82
Hom3
In short smart bulbs are for the rich and spendthrift.
This is my opinion.
What so rich about it? Its surely doesn't cost that much right as one can get it for few bucks a well.
I dont want to waste on alexa etc. I dont plan to use them as not interested at all.
Marcus Fenix
Veteran
Nov 22, 2010
1,347
515
152
Kolkata
Just control the bulb via the manufacturer app only if you go for a non-generic brand.
I have a generic smart plug for my Raspberry pi as well as its tucked away in a hard to reach corner controlled by Alexa as well. I used the app only for the initial setup and uninstalled it aftewards as well.
I am icky about these generic Chinese smart home apps as I don't know what kind of data they are harvesting from my phone. Alexa acts as a sandbox for this stuff in my case.
bssunilreddy
Veteran
Mar 24, 2007
2,085
810
207
41
Nellore
plus.google.com
I thought that the whole setup of smart bulb includes Alexa which is not for me. Which makes the whole setup costing around 10k or more if we purchase more than one bulb.
This is why in my opinion it's a rich man's indulgence.
technofast
Aug 26, 2011
410
110
82
Chennai
I got Syska along with Echo Dot. After a week's time I got bored with it. Just using it as ordinary LED. Maybe if we have series of bulbs to control in different rooms it might be interesting.
ashish
215
18
82
Hom3
I already mentioned that I need only a single bulb. And no ways I'm going to lit my entire house with it, cant invest so much.
Post automatically merged:
Which syska model and what watt? Can you provide the link?
technofast
Aug 26, 2011
410
110
82
Chennai
Reactions: ashish
adder
Veteran
Jul 8, 2007
3,506
353
173
I have 2 xiaomi/yee bulbs yellow/white versions, they are generally appear to be built better then all of the indian and other chinese bulbs. I also have a philips zhirui/xiaomi bulb which only works with MI Chinese servers. Sometimes due to routing issues all the way to chinese servers, I am unable to adjust the settings, initially the same problem was there with the Yee but now it has a option to work with just home network.
The drawback is that they consume around 1.2 to 1.3watt in stand by. All these wifi devices put a strain on the wifi router, which may cause wifi to crash, happened on my netgear R7000. Not so yet on the R7800.
ashish
215
18
82
Hom3
9 watt provided along with echo dot during Amazon sale. I did not pay anything for the syska bulb.
Thanks for the link. I'm thinking to order it.
Guys hows Amazons own Amazon Brand - Solimo Smart LED Light brand?
rajil.s
Apr 19, 2011
443
93
66
45
Somehow i missed this thread. Xiaomi Led is working great for me as reported here.
@adder I disabled internet access to the Xiaomi blub, everything works great using Lan control.
What is Syska based on, Wifi or Zigbee?
sriharsha_m
Nov 1, 2009
644
119
133
Hyderabad
Have been using a couple of Wipro smart led bulbs and Mi ones. App wise Mi is better. Wipro although the bulb is good, app is buggy.
Both give you the option to control the level of illumination, color and saturation.
ashish
215
18
82
Hom3
I read that the rgb colors only emit at 3w and not full 7w/ 9w.
Is there any such rgb bulb which works at full potential without compromising on wattage?
ashvarybabul
Aug 19, 2009
834
24
102
28
Jabalpur
www.flickr.com
I am using Wipro Garnet 9W smart bulb Check here, answering based on experience with it.
1. You can fit it to existing holders. Just make sure to buy B22 one.
2. Wipro had IFTTT feature. So i assume you can program it to switch on to specific color at specific time. (there are some presets also)
3. Yes you can control luminosity to all levels for all colors.
4. I went for wipro coz it was the cheapest option i.e. Rs 500 in sale. So far, 4-5 month usage experience is good and app interface is nice. If price is not constraint there are various options to explore.
