Budget 0-20k Sub 10-15K PC for pharmacy billing with minimal space
Naveen_Reloaded
204
12
81
www.urssiva.com
  1. What is your budget?
    • 10-15k
    • none
    • none
    • planning for a thin client or less space occupying build
    • Not much upgrade for another 10 years. It will be running only one pharmacy billing and stock software.
    • online
    • local
    • Yes
    • Commerical - Pharmacy Billing and Stock Maintanence
    • no
    • no
    1. 720p might do
    • no
    • Windows 7 64 bit
6pack
ex-Mod
Sep 19, 2005
7,657
1,579
302
What minimum hardware requirements does the billing software mention?
Naveen_Reloaded
204
12
81
www.urssiva.com
I think it doesnt need much , i have seen some 5 year old system running it. You know its just a simple software.. not much i think. I havent contacted any software guy though..
I think a 4gb ram with 250GB HDD a decent CPU would do without much fancy other stuffs. like usb 3.0 etc
Post automatically merged:
First i thought i will go wtih all in one pc , but then i thought , with the same amount i can get a better value for money pc.. CMIIW
rdst_1
Veteran
May 10, 2009
2,557
1,147
253
32
Wouldn't a cheap laptop be better. Won't take lots of space in the shop either.
Any basic i3 laptop with 4GB ram should be enough.
Reactions: Naveen_Reloaded
6pack
ex-Mod
Sep 19, 2005
7,657
1,579
302
You will get a better PC, but it will take much more power to run compared to an all in one pc. If you run the pc for 12 hours a day or more, your electric bill will be much more compared to a laptop or NUC. Just the PSU on the desktop PC will take 200+ watts compared to 65W of laptop or even less on an all in one.
I think someone is selling an NUC i3 here. More than enough for your needs and can easily be attached to the back of a monitor with the included bracket.
In that 15k range, even those small Intel Pentium laptops would suffice probably.
6pack
ex-Mod
Sep 19, 2005
7,657
1,579
302
Laptops will do but its keyboard wont stand a chance against harsh use..
NUC might be a better option .. does it have a network port ?
NUC has a gigabit port. Does not come with monitor but it has vga and hdmi port output to connect to TV. If you don't have a tv or monitor then just spending 15k on NUC will blow your budget.
technofast
Aug 26, 2011
375
95
67
Chennai
Couple of months back bought something similar from the local shop. Using it in my friend's provision store for billing purpose. Assembled locally. The price was somewhere similar as quoted by the seller in Amazon for this full setup.
Naveen_Reloaded
204
12
81
www.urssiva.com
True.. I cant afford much .. Actually now i have to get two systems , one for lab and pharmacy..
Thanks. I think i will ask for a mini atx to save space.. is there any downside ?
Also Is it possible to have one powerful system which can be used in two places , like some virtual clients ?
ONE CPU - 2 montior , 2 KB , mouse and 2 printers..
can this work or needs more networking etc ?
Also suggest some good KB and mouse for rough use.
technofast
Aug 26, 2011
375
95
67
Chennai
@vivek.krishnan might be able to clear your doubt
6pack
ex-Mod
Sep 19, 2005
7,657
1,579
302
guys any update ?
Can someone atlezast tell me the system specs which i should be expecting for this price range ? Also how about assembling myself ?
You can get an idea of computer item prices for computer parts on mdcomputers.in, primeabgb.com and amazon india. There are a lot of assembled pc's selling for around 8 to 10k on amazon.
Ask local computer shops if you can get 2 assembled pcs with monitors etc in 15k.
One computer, 2 monitors etc - that is called thin client. You can read more about it here:
Naveen_Reloaded
204
12
81
www.urssiva.com
Thanks for your reply.
I thought amazon items will be a bit costly than the local counterpart , thats why i asked the basic config i should be looking for..
As for thin client , will it be cost effective or would cost more for server etc ? Also will it be up-gradable later on ?
Second hand NUC should work.
any good place to look for , i tried our market place , couldnt find much.
vyral_143
Jarvis
Section Mod
Nov 28, 2011
3,229
1,369
207
香港
@Naveen_Reloaded
https://www.techenclave.com/community/threads/asus-x551m-laptop-for-sale.189876/
I think these fits your bill and usage. For NUC, you may need to get SSD/HDD as well.
6pack
ex-Mod
Sep 19, 2005
7,657
1,579
302
I dont have much knowledge on thin clients. I had learnt about it 22+ years back during Novell Netware days.
If you tell us what software you're going to run on it maybe we can give better and cheaper hardware info too. If its strictly running windows, then just buy one of those cheap laptops / desktop and run an rdp server on it. For the thin client, if your software can run on some low end setup like raspberry pi (debian os) then you could get one of those for the terminal pc and connect to windows laptop through rdp. Raspberry pi is like 3500 rupees but without monitor etc. You can't upgrade it part by part since its just a single board. It was made cheap as possible to dispose after few years use.
Thin client os license for the raspberry pi and intel nuc is very cheap. Free demo for 30 days.
Another rpi client but too costly.
vivek.krishnan
Veteran
Dec 18, 2009
7,469
1,675
303
Ghatkopar, Mumbai
plus.google.com
Yes, you can setup thin clients and save on cost. But it will come back to bit your a** later on.
Sending you my details, will help with this.
I would suggest to get used systems.
