Spacescreamer
ex-Mod
1) What is your budget? (INR)
35k Max
2) What size & weight consideration (if any) would you prefer?
14"/15"/16" FHD screen
3) What are the primary tasks you will be performing with this notebook?
Running software like Autocad etc. The machine is intended for an architect/interior home designer
5) Any typical configuration in your mind you're eying for ?
Apart from an FHD screen,
I have heard that i5 is a must, as the data sets can become heavier.
4) Are there any brands that you prefer or any you really don't like?
Like: Dell, Asus, HP, Acer & others
Dislike: Lenovo (seen horrible aftersales)
6) Anything else you would like to say?
Open to purchasing from ebay, seller warranty pieces
If the suggestion is overshooting the mentioned budget, pls do mention the model/link in any case.
Thanks in advance.
35k Max
Thanks in advance.
