My nephew wants to upgrade to a better gaming rig. Please suggest.
Questions
1. Q: What is your budget?
1. 40K
1. A 2 year old compaq presario. (don't know what model it is)
For the time being he will keep following
1. Monitor - 17" LCD
2. Speakers - Some 2.1 from creative.
1. My only preference is an intel based CPU and a corsair PSU.
1. Yes, will upgrade the following within 12 months
2. Montior - a 24" monitor
3. Speakers - Altec mx5021
1. Delhi, Nehru Place
1. No
1. Gaming
2. Browsing
3. Desktop Processing
4. HTPC
1. This is really important. Please suggest whatever has the best A.S.S.
1. Strategy - Civilization 4
2. Racing - Grid at medium to high settings
11. Q: What is your preferred monitor resolution for gaming and normal usage
1. Gaming - 1280x728
2. Desktop - 1440x900
1. No
1. Windows 7 32 bit
Questions
1. 40K
1. No
1. Gaming
2. Browsing
4. HTPC
1. No
1. Windows 7 32 bit
