meet6600
Hi Friends,
Need help in second phase of my PC Upgrade. I bought Intel Core i3 4130 with stock cooler, Asus H87 Pro (No Overclocking) , 8 GB DDR3 Corsair Vengeance, 1 TB Green WD (Still regret the purchase), Carbide 500R and G400s Logitech Mouse in one go. Already had CX600 PSU, Razer KB, DVD RW and UPS. Now want to go for GFX, RAM, Storage and SMPS upgrade whichever necessary. Kindly suggest,
- What is your budget?
- 30 K
- CPU - Intel Core i3 4130 with Stock Cooler
- Motherboard - Asus H87 PRO
- GPU - Integrated
- RAM - Corsair Vengeance 8 GB DDR3
- Storage - WD Green 1 TB
- Corsair Carbide 500R
- Samsung CD / DVD RW
- Monitor - Dell S2209W Full HD
- PSU - Corsair CX600
- Razer Lycosa Mirror Keyboard
- Logitech G400s Mouse
- APC UPS 800 VA
- CPU Intel Core i3 4130 ( Waiting for Broadwell Core i5 with IRIS 6200)
- Motherboard, RAM and Integrated GPU
- Carbide 500 R
- DVD RW
- Monitor, KB Mouse and UPS
- GPU - Probably 750 Ti GTX
- PSU - If CX600 not good suggest better PSU
- SSD SAMSUNG 850 PRO 256 GB
- 7200 RPM WD Black / Blue
- RAM 8 GB Corsair for vSphere Environment VMware http://www.techenclave.com/community/guides/best-power-supply-units.1/
- Yes, will upgrade in phases. In First Phase got rid of my Old AMD Rig but kept PSU, KB and Monitor to upgrade to Intel Core i3, RAM, Mobo, New HDD, Cabinet and UPS (35k all after deducting my previous config).
- Next and last phase will be CPU.
- Delhi Locally
- No
- Light to medium Gaming
- Browsing
- Desktop Processing
- HTPC
- Download rig
- Watching HD movies
- Prefer Asus, SAMSUNG, WD, Corsair, etc
- Latest Titles at medium or high settings.
- Not intending to utilize Full HD 1080p and have never gone for high or ultra settings
- No
- Windows 7 Enterprise 64 Bit
- Windows 8 Pro 64 Bit
