Suggest trimmer which may work both on direct AC power cum battery
nRiTeCh
If you can see the green dot, I'm online ;-)
Veteran
My Nova trimmer may have died so this time I want a trimmer which will work both on direct AC power cum battery. (if battery isn't charged or goes dead still it should still work flawlessly on direct AC electric socket).
Budget: Not sure but will keep it 3k max.
Brand: Any good brand with good A.S.S
TechFrost
Member
38
1
8
Philips is the best & it can work when powered... Xiaomi has good reviews, but now sure whether they operate while charging, but the advantage is of USB type charger!!
Chaos
Veteran
Jan 29, 2005
9,159
1,026
302
I use a Braun 7020. Pricey but very well built. It works both on power and on battery.
mk76
Dec 4, 2008
836
333
153
Wahl Beret. Quick charge. A tad pricey , but long term investment. If you are in Delhi, pm me. Can get you better price than Amazon
