Suggestion for cabinet + PC for my new Pc
happy20b
New Member
15
0
0
35
Dear All
I want to buy new PC this staturday ..
my budget is 30k ..
In future i may upgrade ram and speakers,
I have thot of OCing at least CPU and may be builtin GPU
So the configuration which i wanted is below
Im not sure if these prices are correct ..
Amd Phenom II x4 630 4.7k
Asus M4A785TD-V EVO 6.5k
Transcend 2GB DDR3 2.5k
WD 500gb SATA 2.5k
Dell ST2210 8.9k
LG/SONY Dvd W/R 1.1k
UPS APC 550v 1.75k
FUTURE UPGRADE ( Excluded from 30k )
Altec lansing BXR1221 0.9k
2GB extra Ram 2.5k
I already have Labtec Wireless Keyboard Optical Mouse combo set
Please sugest best combination of cabinet and PSU within 4k
I am from banglore and i will be buying from SP road..
Thanks
DarkAngel
Veteran
Apr 10, 2009
6,420
321
222
For Cabby and PSU you can consider
CM Elite 310 - 1.6k
Gigabyte Superb 460w - 2.2k (2yrs warranty, efficiency 75-80%, not 80+ certified)
Best bet in your budget.
If you are looking for a better PSU then,
Zebby Bijili without PSU 1.1-1.2k
Seasonic S12II 380w-3k(5 yrs warranty, 80+ certified)/ Corsair CX400(3 yrs warranty, 80+ certified) - 2.8-3k
Other prices seems more or less ok.
happy20b
New Member
15
0
0
35
CM Elite 310 - 1.6k
At my place CM elite costs 1.8k and bijli 1.5k :-(
is nzxt gamma avavilable in bangalore ? and sugest only 80+ certified psus plz
thanks
DarkAngel
Veteran
Apr 10, 2009
6,420
321
222
thanks
The CX400 - 2.8 is the cheapest 80+ certified 400w PSU you can get. But then again it may cost higher at your place.
TheITWares -CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified SMPS
FSP Blue Storm Pro 350W Power Supply - Rs.2,150.00
This is the cheapest 80+ certified PSU i can find.
http://www.techenclave.com/dealers-paradise/master-price-list-hdd-cpu-gpu-159893.html
happy20b
New Member
15
0
0
35
Thanks for the info.. by the i have no plans of adding extra graphics card .. i will just overclock proc and builtin gpu [asus 785td-v evo]
and what about fsp saga II 400w ,vip 500W gold ? and what about nzxt gamma cabinet ?
DarkAngel
Veteran
Apr 10, 2009
6,420
321
222
NZXT Gamma cabby is good. Search TE. There is a thread on this.
FSP is much better than VIP as FSP is a major PSU OEM maker. If you need a cheap 80+ PSU then go for the FSP Blue Storm Pro
happy20b
New Member
15
0
0
35
Not cheap actually .. best minimum priced :)
anyways thanks for your quick replies :)
please suggest atleast 3 cabinet+psu combinations in prioarity , coz this saturday im going to buy PC, in case if first combination is not available then i should have some backup combinations :) .. because here in sp road most of the shops doesnt have proper cabinets and psus
PS: please try to keep total cost below 4 to 4.5k
a]
b]
c]
j1n M@tt said:
if you are ready to spend 3k, Tagan TG500-U37 is the best option for PSU.
Is it really worth to buy such psu when i am not going to buy any graphics cards ? But yes i will overclock built-in gpu
I had mailed theitdepot and their reply is
The product you enquired is available. The total cost (product price&shipping)would be Rs 2120/- The product would be dispatched through professional courier.if placed order.Please view the link for the same
Theitdepot - NZXT Gamma Black Steel Mid-Tower Case
So what you ppl say ?
vinay_thakkur
New Member
40
1
0
36
pune
NZXT is nice for your budget ...
But you if you thinking to upgrade ur PC in near future than rethink ....
As u r thinking of OC ur PC ...
DarkAngel
Veteran
Apr 10, 2009
6,420
321
222
Dont go for the Tagan. It doenst have any proper reviews.
Best option in your budget is,
Corsair - 2.8k from Itwares (3k shipped) --> 80+, 3 yrs warranty, 30AMPs on 12V, single rail.(Good for OC with your specs)
