nikhilpoddar
- What is your budget?
- 15K-20K
- What is your existing hardware configuration (component name - component brand and model) AMD Phenom II X4 920, Zebronics Motherboard (Cheap One), Corsair 2 * 2GB DDR2, Saaphire 512MB 5670, VIP Gold 500W, NZXT Gamma, and I/O accessories.
- Monitor
- Keyboard (USB)
- Mouse (USB)
- Speakers
- Graphics Card
- NZXT Gamma Cabinet
- 1. Intel Pentium 7th Gen. G4560 - NA - Expected price - Rs. 4700
2. Gigabyte TA B250M D3H - Rs. 7200 or Asus B250M Plus Rs. 7500
3. Gskill Ripjaws V 1*8GB 2400 - NA or Corsair Vengeance 1*8gb 2400 - Rs. 4350
4. Antec SMPS VP550P - Rs. 3650 or VP 450P - NA
- May upgrade
- Mumbai
- Open to online purchase
- Yes
- Browsing
- Watching Movies
- Office Work
- No preference
- NA
- 1920*1080
- No
- Windows 10 64 bits
