Budget 21-30k Suggestions for PC build for image editing (Photoshop and Light-room)
amit199013
Dec 4, 2009
308
13
83
Hoshiarpur
Questions
  1. What is your budget?
    • 25K (increased to 60K)
    • CPU - Intel E7300
    • Motherboard - Asus (dont remember)
    • GPU - Nvidia low end (dont remember)
    • RAM - Transcend 2X2GB
    • Monitor - Some dell Monitor, Its a good monitor 24 inches. Planning to keep it.
    • PSU - Local
    • (please mention the rest in above format)
    • CPU
    • Mobo
    • RAM
    • PSU
    • SSD
    • DVD drive( or should i use the older one)
    • Graphics card
    • Cabinet( should be nice looking(black) planning to put it on counter of his studio)
    • keyboard and mouse.
    • No upgrade in coming 3 years at least.
    • Open to online purchase
    • No
    • Image Editing.
    • Not in particular, but after sales services should be good, in case they are requires.
    • Most probably None.
    1. Image editing at 1080p, may be in an year or to resolution may be increased.
    • No
    • Windows 10.
I am planning to build this CPU and gift it to my frnd.
Thank and best regards,
Amit.
bssunilreddy
Veteran
Mar 24, 2007
2,091
813
207
41
Nellore
plus.google.com
Budget -36K
CPU -AMD Ryzen 3 2200G APU-8k
MB -MSI B450M PRO VDH V2-7k
RAM -CORSAIR 8GB DDR4 CMK8GX4M1D3000C16-5k
SSD -Samsung 860 EVO 250GB SSD -5k
Power Supply -Antec Earthwatts Gold Pro 450w -5k
Cabinet -Antec P8 ATX Cabinet -5k
Logitech MK200 -1k
Total -36K
amit199013
Dec 4, 2009
308
13
83
Hoshiarpur
Should i go for ryzen 5 instead of 3 if i increase budget.
I am inclining towards ryzen 5 2600 as this would help in lightroom performance in exporting edited RAW images to JPEG etc.
Also please suggest from where to buy power supply.
Budget is not strict, Just want to build a sytem which would last some time.
Thanks and regards,
Amit.
amit199013
Dec 4, 2009
308
13
83
Hoshiarpur
You would then need to get a dedicated GPU.
Ya will add a low end gpu also. But will it be worth it( ryzen 5 2600 ) or then i5 starts commimg into picture at that budget. That is what i am wondering. Also still not able to find decent psu. I am using seasonic m2 520 watts. Sumthing like that i was looking.
vyral_143
Jarvis
Super Mod
Nov 28, 2011
3,335
1,461
207
香港
Low end GPU ? GT1030 costs like 6K+ and performs similar to iGPU of Ryzen 5 2400G. At that level, you need to consider if gains are worth after spending 10K extra (Ryzen 5 2400G at 12K vs Ryzen 5 2600 + GT1030 at about 22k or more).
Seasonic is good PSU and you have more than enough capacity for you without GPU. M series is modular one so I wonder what are you looking at ?
Reactions: amit199013 and mk76
nRiTeCh
If you can see the green dot, I'm online ;-)
Veteran
You are already good with PSU you only need to decide on cpu/mobo/ram and gpu. If you go with suggested setups or even 2600 ryzen you better off with a 1060 or 1660.[DOUBLEPOST=1551786647][/DOUBLEPOST]For GPU have look at this thread. You should consider the cards here all under good warranty and cheaper than online. You can negotiate further.
amit199013
Dec 4, 2009
308
13
83
Hoshiarpur
Thanks everybody for their inputs.
Sorry for not being clear, i was trying to say I myself is using this seasonic PSU i had bought this in 2017 end. It is still working good. I want to buy a good psu like this.
vyral_143
Jarvis
Super Mod
Nov 28, 2011
3,335
1,461
207
香港
No need to sorry! I went through first post again. Fitting all the stuff in 25K is definitely challenge. In that budget you could fit CPU, mobo and RAM with may be some spare amount to spend.
amit199013
Dec 4, 2009
308
13
83
Hoshiarpur
Processor:- Ryzen 5 2600( this i have in mind)
Mobo :- B450 chipset( Msi or gigabyte)
Ram:- 8 gigs Corsair 3000 mhz as suggested above.
SSD:- Samsung evo 860 250 gb.
GPU:- 1060 bought from fellow member.
PSU:- I am lost here! Please suggest a good one, Antec VP650P V2 650w or Corsair CX series CX600 600W. bothe are available in the range of 4800.
Cabinet:- Antec P8 ATX Cabinet
Budget is not 25k fixed can be extended to arround 40~45k.
vyral_143
Jarvis
Super Mod
Nov 28, 2011
3,335
1,461
207
香港
I think you can either check for Seasonic PSU offline or go with above suggested Antec Earthwatts Gold Pro series. From what I have read, OEM/supplier/partner for this series is SeaSonic.
vivek.krishnan
Veteran
Dec 18, 2009
7,516
1,700
303
Ghatkopar, Mumbai
plus.google.com
Performance of m2 nvme will be far better & faster than SATA ssd
Thats akin to telling that a V8/V12 will perform better than a V6, but if wheels are crap, its pointless. I would suggest NVME only for HEDT setups or where their potential will be fully used.
Usually, a SATA SSD retails for much cheaper than a NVME one, plus its more future proof for current gen because not currently everything has NVME.
amit199013
Dec 4, 2009
308
13
83
Hoshiarpur
Bought all the following components, thanks everybody for their valuable inputs.
ryzen 5 2600 ₹16,290
8gb 3000 mhz(corsair) ₹4,485
gigabyte aorus B450 elite ₹9,912
1060 6 gb(from fellow member)
Antec earth watts 550 pro gold ₹5,900
Samsung 970 evo 256gb m.2 Nvme ₹7,290.00
Antec p8 cabinet. ₹5,800.00
Parts will be delivered at around 13th.
Will update after the build.
Regards,
Amit.
Reactions: vyral_143
