imkaush
1. Budget?
A: ~3k
2. Preferred Form Factor(flip, bar, slider)?
A: Bar
3. Preferred display type?
A: Any
4. Do you have any brand preference or dislike? Please name them.
A: Trusted brands(Nokia/Samsung)
5. Preferred input method (Touchscreen, QWERTY, etc.)?
A: Touchscreen only
6. Camera required or not? If required, please specify type like front camera/flash/etc.
A: Rear Camera Required. No problems with lesser MPs.
7. Preferred operating system? (Android, Symbian, iOS, Windows Phone etc).
A: Android/WP/iOS would be too complicated.... any simple Symbian-like OS preferred.
8. Preferred connectivity options? (3G, Wifi, Edge etc).
A: Not required/Not used.
9. What is your intended use for this phone(internet, camera, multimedia, mails, etc)?
A: Mainly Calls. Camera will be used rarely.
10. Any other requirements?
A: Don't require dual sim. PC-connectivity for contacts-backup, if possible. Require best battery life.
11. If you have already considered a phone then please mention the model.
A: None
Suggestions based on experience are most welcome!
A: ~3k
A: Bar
A: Any
A: Touchscreen only
A: None
