Sister's pc need an upgrade. Pls help me with the choice of components.
Preference
- M-ITX build
- onboard graphics
- onboard wifi if feasible
Preference
- M-ITX build
- onboard graphics
- What is your budget?
- 25-30K for CPU, Mobo, RAM 5K for SSD,
- CPU - Intel E8400
- Motherboard - Gigabyte compatible .. (don't remember the model)
- GPU - On Board
- RAM - Corsair DominatorXMS 2x2GB
- Monitor - Dell ST22
- PSU - Corsair VS450
- Cabinet - CM K380
- HDD - 500GB + 2X1TB WD Greens
- (please mention the rest in above format)
- Keyb/Mouse
- HDDs
- Cabinet
- CPU - Intel or AMD
- Motherboard - any compatible motherboard .. Mini ITX if possible
- RAM - 8 or 16GB
- SSD - for boot
- PSU - If it need upgrade
- GPU - On Board
- Monitor 24-27"
- Cabinet - if required
- Delhi
- Open to online purchase
- Yes
- Browsing
- Desktop Processing
- For kids in middle and senior school
- Office
- Photoshop
- Scratch / Logo
- Python
- Preference is durabilty as it won't be easy to RMA every now and then
- On-board should suffice
- No
- Windows 10 x64
