Q: What is your budget?
10-15 K
CPU - Intel P4 1.4 Ghz
Motherboard - MSI Intel 845
GPU - TNT Riva 64 MB
RAM - 512 + 256 + 64 SDRAM PC 133
HDD - Seagate 160 PATA
Monitor - Samsung Syncmaster 19 Inch
SMPS - 400 Watts
DVDRW - Sony PATA
Speaker - Creative 5.1 Inspire
Peripherals - Logitech Mouse KB Combo
HDD - 160 GB PATA ( with PATA to SATA Convertor )
Sound Card - Creative SB Live 5.1 on PCI Slot
CPU - Intel Core 2 Duo / AMD x2/x3
RAM - 2 GB
Motherboard - any compatible motherboard ( This should have support for atleast one PCI Slot ) for the Creative PCI Soundcard
GPU - On Board
Cabinet - Mid size with SMPS
Yes, will upgrade the following within 6 months
RAM - 1X2GB
Delhi - Nehru Place
Open to online purchase - No
No
Browsing
Desktop Processing
Download rig, 24x7 operation
Watching HD movies
No brand Preference
No games.
Gaming - NO
Desktop - 1440x900
No
Primarily Windows XP SP2
Windows 7 64 bit ( In the Long Run )
Linux - Ubuntu (Sometimes )
Please Suggest
Thanks
10-15 K
SMPS - 400 Watts
DVDRW - Sony PATA
RAM - 2 GB
GPU - On Board
RAM - 1X2GB
Delhi - Nehru Place
No
Browsing
Desktop Processing
Watching HD movies
No brand Preference
No games.
Gaming - NO
Desktop - 1440x900
No
Please Suggest
Thanks
