^ Why didn't you PM me? :S
I seriously came here hoping to be able to help you and you had indeed called for me- which sense would that be? :O
I am unable to promise anything but will surely try my best.
First of all, stop using that rig without SB cooling asap.
People have ignored and have ended up with fully dead or partly/hardly functional mobos.
The ASUS one doesn't fit msi iirc, not sure now.
Have a lot of DFI ones but none has a fan but obviously- Sunon whiners on sterioids- had to die eventually, some even flying off while in use. :rofl:
Have a few passive ones too- maybe useful but depends on the gpu used.
What gpu do you use on that?
Please PM me a pic of your mobo with the gpu seated.
Next, measure the distance between the 2 holes and let me know.
Will dig in my junkyard and hopefully find something suitable for you.
Else will have to look for cheap stuff on DX or pricier stuff on NE/SW. :ashamed:
