blr_p
Wanted to recharge a 3g plan on airtel here in karnataka.
RC145 on airtels site says 28 days validity.
when i went to a local shop and had it done i find out its only 21 days of validity. When i ask the guy in the shop about it he says airtel has reduced the validity. When i called up airtel's CC they confirm the plan is still 28 days. So when i spoke to a supervisor he said they have used ezrecharge, i don't know what recharge site the shop used. But i ended up with 7 days less validity on my plan because i did not use airtel's recharge which in fact is easy and can be done via USSD provided enough prepaid balance is in the account.
Am surprised that there is a difference in what you get using 3rd party sources in case of some plans. The supervisor said he could not do anything but advised to check validity before recharge. In reality it means check airtels terms for the plan and then compare.
Do these online recharge sites play around with validity as well ?
