VR device for iPhone 6
anish_sha
Happened to know about the VR thing recently.. Would like to try on my iPhone 6. suggest me one
does this comes with headphones
can it be used to watch movies? is long time watching bad for eyes?
No headphones or anything just 2 lenses which curve the smartphone display , you can buy a VR box,I got mine for around 200rs locally.
There is almost no difference between cheap VR headsets .
They are tbh gimmicks and nothing else,
I had a Oculus rift,used for less then 2 hours.
The FOV is pretty narrow and don't expect anything immersive, also a 5.5inch display is required for best fov,on a i6 it will look even worse .
