overclocked
MY viewsonic VX 2025 had some problems so the viewsonic agreed to replace it but the real problem is that they don't have 2025 in stock as it is out of production, so what they finally decided after 2 months is to replace my 2025 with a 2235.
But the 2235 is TN pannel and the 2025 is a p-mva pannel so what should i go for.
moreover the issue was with the heating of the LCD pannel and then it used to go just blank or flicker. I checked the viewsonic site and they had mentioned that the operating range of the monitor was from 5-35 degrees whereas room temp here would b like 32-35 degress on summer, but a LCD pannel working would be at a higher temp than room temp so what i did was that i placed a pedestral fan behind the LCD and since then it has been working just fine. Also there would be no guarantee that the 2235 won't heat up like the 2025.
So what do ya guys suggest????????????:S :S :S :S
