Monitors Where can I buy 30"x19" stacked monitor
Vij
I need your help guys. I am interested in buying a joined multi-display setup like so -
http://www.digitalti...powertrio30.asp
Not quite 3 as in the above pic - All I want is a 30" main screen with a conjoined vertical 19" to the left - (not separate display). Any ideas where I can buy this in India/Hyderabad ?
I am into a lot fo different stuff at the moment work wise and can benefit with this setup.
Many Thanks
You do realize that the linked setup is actually 3 different screens on articulating arms?
You can do this yourself, would just need to source a good mount.
Ergotron makes some great mounts. A little pricey, but I'm assuming that isn't a big deal for you?
Pretty slick
The arms are an overkill but there are other simpler mounts there too I guess. Thanks for the info. Only gripe is I have to buy these mounts and monitors separately.
