Which Bosch/Siemens washing machine for 35000/-
raja_mastana
Apr 9, 2006
549
133
132
Looking for 8kg Bosch or Siemens front loading washing machine
Budget: Around 35k
I have selected two models
Bosch WAT2846WIN (MRP 42,200)
Siemens WM14T461IN (MRP 40,700/-)
The one dealer I met offered 15% discount on the Bosch (including exchange existing machine) which makes it 35,870/- . He suggested discount on the Siemens would not be possible, but said he can offer a deal on the day I wanted to buy (i guess 10%).
Advantages
Both have similar feature like brushless motors, pressure sensors, quite operation etc.
Bosch model has anti tangle feature - not sure how effective it is.
Anyone knows about Bosch or Siemens washing machines - please help deciding
blr_p
Veteran
Apr 11, 2007
5,883
1,241
301
Missed this post, how high is your water tank from the machine ?
I had considered Bosch but back in 2015 they were asking for higher water pressure than I thought my overhead tank could provide.
What is your current model washing machine ?
Hard to separate these two out, they are identical even with weight with different face plates
Bosch WAT2846WIN
Siemens WM14T461IN
rdst_1
Veteran
May 10, 2009
2,515
1,114
253
32
Generally Siemens machines would be more expensive for similar model. Siemens has already sold off it's share in the appliance business to Bosch. Even before both machines are usually same and even manufactured in the same facility.
In our first residence, the overhead tank was around 15-16 ft above the machine and the pipes were clean, so there was never any issue due to water pressure. In our second home, the machine inlet pipe had to be extended and there was blockage in the pipes, so it would throw E17 error and remove the water and soap without using it.
In our new home, tank is 25ft above the machine and I used 3/4 inch pipes for plumbing and here there is no issue with water pressure. Overall very happy with our Bosch 5.5kg machine which we have since 2012.
More than pressure, it is the volume of water that matters. Even the pressure switch inside the machine just checks the volume of water that has entered the machine in the inlet cycle. If it is less than the required volume, it will eject all the water alongwith the soap. In that case we used to manually fill the same water back using the detergent compartment and resume the cycle. Since now it had enough water the error wouldn't return, until the next inlet cycle of the wash cycle. It was difficult to use the machine for the few years we had this issue, but it was still 90% less work than the semi-auto machine it replaced.
Reactions: blr_p
raja_mastana
Apr 9, 2006
549
133
132
I am on the first floor apartment of a 3-storey building. Water pressure feels good, but not sure how much these machines needs.
I currently have an LG top loading washing machine. It has served me very well all these years. I got this as factory seconds as it had a huge scar/dent on the body. But, its body is now rusted and has already been repair a couple of times recently. It will break any moment.
Hmm whats with the Bosch/Siemens washing machines and water pressure, even the dealer was asking me about my apartment and water pressure. The problem you described is a deal breaker. Can't imagine manually filling water in a modern Siemens fully automatic washing machine. :p
Btw i visited a different local dealer here and he was offering 15% discount on the Siemens washing machines too. He also said he can try to make it better on the day.
Also came across horrible after sales reviews on mouthshut.com for Bosch/Siemens like high visiting charges, expensive spares etc. All these makes me wonder about these German engineered machines :rolleyes:
rdst_1
Veteran
May 10, 2009
2,515
1,114
253
32
If you don't have blocked pipes, there won't be any issues. There was nothing wrong with the machine. It's a fully automatic machine, so it has a fixed time for water inlet. They have to build a contingency that the machine won't work if the amount of water entering during the cycle is lower than the required amount. In our semi-auto machine, we used to have a fill mark upto which we used to fill the machine. So there has to be a sensor based counterpart for that function.
Mouthshut will always have bad reviews only. It is where people come out to vent. I have been impressed with my machine so far and there hasn't been even one issue with the machine that required repairs. I even bought a Bosch dishwasher because I was impressed with the reliability even though the nearest service centre is 300kms away for me. It is being used twice everyday since October and no issues there either.
Reactions: raja_mastana
blr_p
Veteran
Apr 11, 2007
5,883
1,241
301
That should be enough. I'm on the ground floor of a two storey building, around 15-16ft to the overhead tank. If you want to dbl check ask them to send a tech over with experience of installation to check before you buy. Tell them you will not consider Bosch/Siemens otherwise. Make him check the water pressure and ask him which company to go for in terms of service & parts. The Siemens brand is more known in India though, they've been here since the 60s. Whether that means anything today i don't know. If you live in a Tier 1 city, service is generally not a problem with any known brand.
I have discussed this earlier on the board search for water pressure, these companies require at least 1 bar pressure. I opted for LG as it could manage with just 0.3 bar of water pressure. However this is no longer true with the latest LG washing machines though. adder's LG machine also wanted 1 bar just like the bosch/siemens.
Seems they want to clear stock. The machines of either are good from what i've heard of owners here. The repair guys are well trained and equipped.
TechFrost
Member
32
1
8
As long as the device is well maintained, it’s a beauty of silence.. hope you haven’t experienced with service!! It’s expensive , compared to IFB or others, the underhood issue with overpriced spare is, they don’t manufacture in India and import from German;
technofast
Aug 26, 2011
345
87
67
Chennai
I've had Bosh washing machine for the past 5 years and for the past couple of years when there was enough water (or the water was more than half full) in the overhead water tank there was no problem but from a year back due to water scarcity the overhead water tank is kept only 1/4 full. After initially starting up the machine never works and throws error for want of water pressure. I live in a first floor and there is no pressure at all with 1/4th overhead tank capacity. To overcome this I had to install a pressure pump near the washing machine inlet/outlet pipe. I had to spend additionally 2k for this pump. After installing the pump there has been no problem. This should be the permanent solution if there is no water pressure.
blr_p
Veteran
Apr 11, 2007
5,883
1,241
301
How high up is the tank from the washing machine. You are on the first floor of how many storey building ?
blr_p
Veteran
Apr 11, 2007
5,883
1,241
301
How much do they charge for a home visit ? leave aside any costs for spares. Just for a house call how much is it ?
technofast
Aug 26, 2011
345
87
67
Chennai
It is a one floor building and the water tank in the terrace is 30 feet away which prevents the pressure to reach the washing machine.
blr_p
Veteran
Apr 11, 2007
5,883
1,241
301
I see, one storey building means the tank is only 9 - 12? feet directly above. On top of that if its only quarter full so pressure is lower because pipes used are inadequately thin. Could even be airlocks.
Interesting point that a tank that cannot be kept full is going to have water pressure issues. I suppose this should be a required test.
Don't just test with the tank full, also test with it quarter full and ensure there is enough pressure :)
technofast
Aug 26, 2011
345
87
67
Chennai
Even in the one storey building if the tank is directly above the pressure will be good but unfortunately the tank here is far away from the point of delivery that is 30 feet away as I mentioned earlier. However, there is sufficient water pressure for the people in ground floor.
skoka123
May 2, 2008
420
119
132
Forget the reviews on mouthshut. I would rather you ask your questions regarding product feedback on Amazon. Even reviews on Amazon can be fake but generally the answers to questions are genuine. Regarding the service quality and costs, it depends on who your local service has been franchised to. I had horrible experiences with IFB washing machines. So far the service from Bosch/Siemens (I have both as I own a Siemens Washing Machine and a Bosch Dish Washer) has been top notch. I guess they use a franchisee with better knowledge and ethics. One time we put in a doormat in the washing machine and the doormat was completely destroyed with thousands of small pieces of cotton coming off the mat. It was our mistake to put it in the washing machine in the first place. The outlet was jammed and the drum just would not rotate. I had the service guy spend 2 days with the machine to remove all of the stuck cotton fragments. I was charged just Rs. 800 for it. This was in Hyderabad.
blr_p
Veteran
Apr 11, 2007
5,883
1,241
301
Give us some details about this pump, brand name and post some pics. Will be useful for future reference.
technofast
Aug 26, 2011
345
87
67
Chennai
I bought it through Amazon and the price is around 4,250 when I bought it and not 2K as I had mentioned it wrongly earlier. Seems like the price has gone up now. Also since I store water in loft tank inside the house I use the pump two way that is from overhead tank and also from the loft tank. Requires some plumbing work. Below link of the water pump-
Reactions: blr_p
blr_p
Veteran
Apr 11, 2007
5,883
1,241
301
You said you have it near the inlet for the washing machine. It looks quite big in the picture so its stored outside nearby ? how is the noise
Looking at the reviews, many seem to have installed at on the top next to the tank. This way all taps in the house will get the pressure.
Its auto so comes on when the tap is open and stops when it is closed.
technofast
Aug 26, 2011
345
87
67
Chennai
It is installed inside the bathroom where the washing machine is kept in a corner. The pump is installed above the washing machine but it is not necessary that it requires to be near the washing machine. It can be even 20 to 30 feet away as the pipeline will deliver the water with good pressure. I have installed it in a way that all the taps gets the pressure when the motor is operated and yes it auto stops when the tap is closed and opens when the tap is operated again. However, there should not be any leakage in the pipes that the water moves, if there is leakage the motor will not stop running until the leakage is plugged.
