which is best DAIKIN JTKJ35TV16U or whirlpool 1.0T MAGICOOL PRO 5S
Sree19291
New Member
3
0
1
Hi,
I have contemplated to buy an Air Conditioner, 1 ton would suit my need for now. can you please advice which is a best choice between the below models considering all features, power efficeiency.
1.https://shop.godrejappliances.com/godrej-gic-12-gtc-5-wsa-1-ton-split-inverter-ac.html
2.https://mydaikinstore.com/daikin/inverter-5-star-1-tr-jtkj35/p-12032-34578322989-cat.html#variant_id=12032-88650320267
3.https://www.whirlpoolindia.com/air-conditioners/split-ac/10t-magicool-pro-5s-copr-inv#gref
market price wise there is a difference of 14k from godrej,whirlpool compared to Daikin
blr_p
Veteran
Apr 11, 2007
6,212
1,346
301
Have you compared the features and are there any you must have ?
Post links for the two from manufacturer website so others can check them out
adder
Veteran
Jul 8, 2007
3,472
278
173
I have the 1.5 ton version of that daikin model, albiet its a older a JTKM series but has the same ISEER rating. That Daikin model is clearly most efficient, if not the top 2 in india, despite the fact that the model is now almost 3 years old.
The daikin comes with the gas and liquid copper pipe with insulation in the box, also included is the 4 wire cable to control the outdoor unit. In the godrej it will have to bought separately and that alone will cost atleast 4k.
Plastic build quality is again better in the daikin.
Reactions: Sree19291
Sree19291
New Member
3
0
1
I have included product links from Manufacture site, Kindly review them
