Which Smart electrical switches?
Crazy_Eddy
Super Mod
Feb 7, 2005
8,516
1,260
303
119
Posting on behalf of @gmano
He wants to know what are some good smart electrical switches.
Or what sort of provisions to make in his wall to accommodate future smart switches?
blr_p
Veteran
Apr 11, 2007
6,193
1,331
301
Where is gmano these days ? i remember his avatar was this guy typing away non-stop.
evilwit
Active Member
196
72
41
29
There are broadly two types of smart switches available. Touch/mechanical smart switches with generally wifi as a communication protocol and small relays that goes behind existing switch boards. They usually use zigbee or z-wave or wifi as a communication protocol. While it is recommended to use z-wave/zigbee as they are more robust but wifi switches are cheaper than them. I recently got my home done from a guy ,my friend knows in gurgaon. I am pretty sure he does projects PAN india. I got 8 z-wave relays from fibaro and 1 zwave gateway. So far it works great. Great thing is it is not dependent on cloud for local control which means i can control all my appliances even if my internet goes down as long as i am in same wifi network. And all of this is wireless so there was no civil work.
Reactions: gmano
rajil.s
Apr 19, 2011
413
80
66
45
The problem with zwave is that the frequency in India is different from US and UK. Hence the cost of zwave products is much higher in India due to much lower volume.
A better choice is to use Zigbee or wifi which have the same frequency everywhere. For wifi switches look into Sonoff.
Abhi2312
New Member
2
2
3
While Choosing Smart Switches and making your home a smart home you need to consider below given basic features in smart switches.
  1. Bluetooth and Wifi Connectivity
  2. Presence sensing automation
  3. Energy monitoring
  4. Integrated automation with other smart gadgets
After considering these things while buying smart switches I have selected 3 smart switches (brands):
1. Smarteefi Smart Switch
2. Sonoff Smart Wifi Wireless Switches
3. TP-Link Smart Single Pole Wifi Light Switch
Reactions: gmano
blr_p
Veteran
Apr 11, 2007
6,193
1,331
301
  1. Bluetooth and Wife Connectivity
:wideyed: :D
Gagneur
New Member
4
1
3
Different frequencies does not make much of a difference. Its the licensing fees manufacturers have to pay silicon labs(zwave parent company) plus when you import zwave products in India it is bound to get expensive. But all things considered zwave is still the best protocol we have as of now for Home automation systems.
Reactions: gmano
superczar
Veteran
Mar 17, 2005
4,469
545
202
39
Based on personal experience, stability-wise, zigbee>z-wave>Wifi
BT is pretty much useless for a production environment
@gmano - What are you hoping to achieve?
Feel free to call me if you need any inputs
Reactions: gmano
gmano
Jan 11, 2007
975
561
202
My idea is to make some switches operable through wireless (say like, switch off the car park lights from second floor). Not expecting to do anything fancy, just some practical solution.
So far I have zeroed in on Sonoff Mini.
superczar
Veteran
Mar 17, 2005
4,469
545
202
39
I presume you will have wifi coverage where the lights are wired
Sonoff mini will work fine for your needs - You could leave it with the stock firmware and use the default app which relies on a cloud connection
Alternatively ,you could load an alternative firware like sonoff-tasmota and change the control model to local lan based
Reactions: gmano
Gagneur
New Member
4
1
3
Default app (ewelink) has the ability to work even if the if the internet is down. Its called LAN Control. As long as you're in the same wifi network as the mini, you can control the device. Additionally Sonoff Mini comes with the DIY mode that exposes the GPIO headers which allows users to easily flash the custom firmware of their choice. But IMHO the OP can easily use the default app and even use the traditional switches as the mini can be installed behind the switchboard.
Post automatically merged:
Sonoff Mini is good choice. You can also take a look at motion/ldr sensor enabled lights if you want a even simpler solution.
