Why cant we get Good quality Data cables in India ?
Discussion in 'Mobiles and Tablets' started by Mr India, Nov 5, 2015.
  1. Mr India
    Mr India Banned
    Samsung cable lasted 10 months and stopped charging unless you hold it in a weird angle. Flipkart /amazon/ local shop cable gone bad in 1-3 months. Literally every cable i see online has bad reviews that most dont even give charge upto 2A max or sometimes dont support data and give charge upto 0.8 amps only. I need cable that can transmit upto 2 amps. Is there any good company that guarantees high current rate and is available in many sizes ? like at home i need a 1.5-2 m cable but in my car i only need a 15 cm cable to connect to car charger im planning to buy. someone plz help its getting frustrating buying cables and wasting money. I have samsung and blackberry phones
  2. axeman
    axeman Ye Olde Systems Breaker
    Veteran
    Bandridge, Bluerigger. But any cable you buy will go bad sooner or later if you abuse it.
    mh09ad5578 and Mr India like this.
  3. OP
    OP
    Mr India
    Mr India Banned
    I dont abuse them. Earlier they made chargers and cable much better quality. Uaed to last years with rough use. Now even being delicate they last few months max
  4. Marcus Fenix
    Marcus Fenix Well-Known Member
    I am using a Rock cable with a One Plus charger for the last year as my ready to use charger in my laptop bag.Has been working so far without any issues.This is used daily and not very gently too.
    http://www.amazon.in/Universal-Micr...qid=1446744040&sr=8-2&keywords=rock+micro+usb
  5. OP
    OP
    Mr India
    Mr India Banned
    me too like it buy some reviewer say it support only upto 0.8-0.9 amps and wont work with the 2 amps fast charger
    --- Post Merged, Nov 5, 2015 ---
    purchased bandridge thanks to this thread
    #5 Mr India, Nov 5, 2015
  6. itspriyank
    itspriyank Well-Known Member
    I have two Kindle charging cable which I received with my Keyboard and Paperwhite ones. Both are amazing cables. The ones which I had received with my keyboard one is still going strong even after 5 years and the second one is also in great condition. I use them very roughly.
    I use them for daily phone charging as they are very good in length.
    I even bought one from amazon for daily needs and they are of great quality.
  7. delhiboy1
    delhiboy1 Member
    Just my two cents: Bandridge is pretty shitty. Go for Bluerigger. Belkin ..
  8. dissel
    dissel Well-Known Member
    BlueRigger is very Good .... How is the Amazon Basis ?
  9. OP
    OP
    Mr India
    Mr India Banned
    i ordered it but. should i cancel it and buy amazon basics or blue rigger? if i cancel i also have to pay extra 40 rs for the other item as it will become under 499 order and i cant add item to order once made i will have to place new one.
    #10 Mr India, Nov 6, 2015
  10. axeman
    Veteran
    I have 6 feet USB to Micro USB Bandridge cables in both cars. Almost 3 years old, and work just fine at 2 Amps.
    Mr India likes this.
  11. nRiTeCh
    nRiTeCh ╙TÉçhkⁿºwªy±iVé»╖
    Veteran
    BTw why not buy the original cable instead if you can get hold off? Else buy the same original charger.
    My cousins S4 cable died off within 18months and he tried many cables but all dead or charging very slow.
    Finally he gave up and bought new original charger itself and its all sorted now.
    Also anything above 1 meter wont support 2amps and thats a norm unless officially supported by that cos. charging capabilities.
    I have extended my xperia z3 charger cable using 2 apple usb cables. Now the length is approx 4 meters. My phone charges slow even though it shows charging at usual 4.18volts.
    But I dont mind as my bed is far from the charging sockets.
    #12 nRiTeCh, Nov 6, 2015
  12. OP
    OP
    Mr India
    Mr India Banned
    original cable for 800 rs. too much plus i have to go to shop to buy and online we dont get it ! yes the shorter the better. My power bank cable is like 15 cms but amazing quality and charging though nowdays data in it stopped and only charges. when i bought i used transfer data too :/
    --- Post Merged, Nov 6, 2015 ---
    so long cable why in car ? im gonna use the power bank cable thats 15 cm in car and use this bandridge with home charger and power bank.
    #13 Mr India, Nov 6, 2015
  13. GreenJay
    GreenJay Active Member
    I had the same query a few months ago here.. Based on their feedback bought Bandridge for my wife and me.. Got my colleagues bought them too. Very solid and still working under various twists and folds..
  14. axeman
    Veteran
    Big cars need that much cable reach o_O
  15. OP
    OP
    Mr India
    Mr India Banned
  16. vidyut
    vidyut Member
  17. Marcus Fenix
  18. nRiTeCh
    Veteran
    Such crap apps itself are battery eaters hoggers and consumers.
  19. Marcus Fenix
    Well don't keep it installed.Just run your stats and get rid of it ASAP.At least that's what I do for Antutu and such benchmarking apps.
Share This Page
