thetoxicmind said:On a budget, I'd have to say a Samsung or LG Window AC (also recommended by AC Technicians).
If you are overly concerned about the *star* rating, consider Voltas.
Capacity depends on how big the room (intended for) is.
Given that you have a fixed budget, narrow down options accordingly.
sunny27 said:are above models are split acs? i wanted info on good and cheap 1~1.5 tonne window acs
