Wireless game controllers
meetdilip
Oct 9, 2011
668
106
81
I am a very limited gamer who use PC for gaming. I want to connect my PC to 43 inch Mi TV as monitor and play some games. I have a desktop CPU which I can use with the TV. Now I am looking for a wirless gaming controller to play games like Asaphalt, GTA or NFS. I plan to do multi player offline games ( 2 guys ).
Can someone suggest controllers which are affordable and good at the same time. Is it recommended to do a wired controller which gives enough wire lenght to enjoy the screen ? Or a wireless controller which will work common games ? Thanks.
adventureguy
Veteran
Nov 16, 2015
1,204
550
126
Hyderabad
If you want cheap, get redgear wireless one, gamesir g1s wireless. both use windows drivers and your pc will detect them without any problem .
I personally use gamesir one since it comes with bluetooth support also so I can connect it with my phone if I want.
if you want gold standard though, get the xbox one controller (new one comes with 3.5mm input and bluetooth). or buy xbox 360 controller. (be careful, a lot of well made fakes of 360 controllers are out there)
Reactions: meetdilip
blr_p
Veteran
Apr 11, 2007
5,870
1,236
301
Some pretty god reviews for it
https://www.amazon.in/GameSir-Bluetooth-Controller-G4s-Black/dp/B01HNXGKT6
Was looking for a wireless controller for old arcade games on mame. only need a joystick and a couple of buttons.
adventureguy
Veteran
Nov 16, 2015
1,204
550
126
Hyderabad
I'm using this gamesir G3s since one year with no problems. It works with pc and phone wirelessly with no problems at all. I don't game much but the times I do, it works fine without any problems.
