Wireless headphones in 8K
ankxxs
Active Member
Dec 2, 2009
367
8
31
33
Hello Friends, I am looking to buy good wireless headphones (not IEM) for my wife. Please suggest.
Thank you
blr_p
Veteran
Apr 11, 2007
6,181
1,326
301
Those cheap ones most likely have class 2 radio receivers. Range is 10m or 30ft unobstructed
Class 1 with higher end headphones have a range of 30m or 100ft. Think about that when you're in the house. Wireless means freedom to move anywhere
blr_p
Veteran
Apr 11, 2007
6,181
1,326
301
Brother it is, othwise I would have galdly chose, first suggestion.
i don't believe you :)
[DOUBLEPOST=1533807625][/DOUBLEPOST]skullcandy grind vs the SE 4.5
https://www.rtings.com/headphones/tools/compare/skullcandy-grind-vs-sennheiser-hd-4-50/477/476#usage*5003!threshold*0.1
looks like the grind & jbl e55bt have a class 1 (100ft range) radio after all
https://www.rtings.com/headphones/tools/compare/jbl-e55bt-vs-sennheiser-hd-4-50/532/476#usage*5003!threshold*0.1
ankxxs
Active Member
Dec 2, 2009
367
8
31
33
blr_p
Veteran
Apr 11, 2007
6,181
1,326
301
When going for wireless headphones i insist wireless range be better than smaller BT headsets. Fortunately both grind & JBL have good range.
https://www.rtings.com/headphones/reviews/skullcandy/grind-wireless
https://www.rtings.com/headphones/reviews/jbl/e55bt
Up to you to decide which you want.
https://www.rtings.com/headphones/tools/compare/skullcandy-grind-vs-jbl-e55bt/477/532#usage*5003!threshold*0.1
Read some more and ask owners what they think.
Battery is less with on ears but then weight is as well.
Reactions: ankxxs
ankxxs
Active Member
Dec 2, 2009
367
8
31
33
I think a visit to Croma is in order for sampling JBL.
blr_p
Veteran
Apr 11, 2007
6,181
1,326
301
Cowin E7 has the best wireless range but won't pair with more than one device simultaneously
https://www.rtings.com/headphones/tools/compare/cowin-e7-vs-jbl-e55bt/466/532#usage*5003!threshold*0.1
Cowin sound quality isn't as good as the JBL either
https://www.rtings.com/headphones/reviews/cowin/e-7-active-noise-cancelling-bluetooth[DOUBLEPOST=1533817126][/DOUBLEPOST]
Then should I go for them?
What other criteria besides price ?
Comfort, weight, ease of use, battery back up etc play a role too
and then there is sound quality, flat, coloured
How long will they be worn in one session etc
One thing is clear, range will not be an issue with any of the four models suggested. This at least ensures you get good reception which matters for wireless.
ankxxs
Active Member
Dec 2, 2009
367
8
31
33
I creased the budget to 8k and gonna go for Sennheiser
blr_p
Veteran
Apr 11, 2007
6,181
1,326
301
Not having it as everybody in my circle has non SBI accounts
you get 10% off 7490 if you use an SBI card otherwise its 7490 fr that lightning deal that will expire soon
manju_rn
Active Member
153
39
41
45
Ankxxs,
Please do audition of the headphones in a nearby mall, since headphones are very personal - some people like "over the ear" or some like "on the ear". I have seen ladies more often like on the ear so that it does not interfere with their big earrings :) 4.5 BTNC are over the ear.
Also, I am wary of the 4.5 BTNC SE (Special Edition) - these sell at half the price of the regular 4.5 BTNC (only during certain sale), so what is so special that they sell half the price? Also, they are not listed in the official Sennheiser site in any country.
If NC is not really required, 4.4 BT has a good enough isolation
blr_p
Veteran
Apr 11, 2007
6,181
1,326
301
Am wondering about that too but there's been lightning deals for things at half price before. My router what i paid and what people here who got on a lightning deal paid. Same product, half price
