Xbox One X Vs PS4 pro
savrom
Active Member
92
27
31
Which console do you think is worth it. Xbox One X or PS4 pro?
krugur
Gaming Freak
Apr 27, 2010
1,047
78
87
Bangalore
One important thing to also consider is Xbox exclusives are currently also available in windows store. PS4 is not so.
Also the cost of xlive / PSN if you are planning it for online gaming mainly.
Reactions: Crazy_Eddy
prabs
Veteran
Jul 24, 2006
1,596
453
172
Xbox One if you want backward compatibility
PS4 Pro if you want good exclusives
Neo-N
Veteran
Mar 26, 2010
1,812
211
152
Mumbai
PS4 Pro - I have one so I am biased! But I never really liked Microsoft gaming... and PS has some really good exclusives!
Chaos
Veteran
Jan 29, 2005
9,159
1,026
302
In terms of pure GPU horsepower, the XBOX runs circles around the PS4 pro. However do make a choice based on what games you play as PS4 has quite a few exclusive games that do not appear on Microsoft's console. The difference between the PS4 and PS4 pro is not that significant as the difference between the Xbox one and Xbox one x. The former barely runs at sub 900p resolutions while the latter runs perfectly well at 2160p on most titles.
Shubham1401
Jan 10, 2011
373
113
81
27
PS4 pro for the exclusives!
Although I would like to make a case for PS4 if you have a full HD TV. Being in the same generation, I don't think there will ever be a game which won't run on PS4 and on the Pro. And there are only a handful of games which really takes advantage of the extra muscle of the Pro.
