esanthosh
Preface
It's been a long time since I wrote anything resembling a review, because I find it a tedious and boring process. But this is a little bit exciting. Yamaha EPH-100 happens to be IEM #74 for me. Quite possibly my #75 may not be as exciting, because EPH-100 truly a Jack of all trades.
Apart from buying numerous IEMs, there are only two ways to listen to many others without spending cash out of your pocket - review samples and loaners. I have developed a slight aversion to review samples. It was not really due to 'manufacturer defect', but the way the process works. I really do not like to be scheduled by others, but that's precisely what happens with review samples. Most manufacturers would want to strike the iron while it's hot and you, whether you like it or not, are committed to doing something within a time frame. Loaners (usually) come with less strings attached and usually from people who know and understand you. So, my 74 IEM ratio in terms of Bought: Loaners: Samples works out the same way - 52 : 17 : 5.
Until abhi_jollyguy offered his Yamaha EPH-100, I only knew it by it's reputation - yet another head-fi FOTM. Interestingly, Joker did his review recently and it scored 8.9. So I thought that may be like MonoPrice 8320, it was not all hype and smoke screen. It is when abhi_jollyguy started asking me questions that I was forced to search the enormous EPH-100 thread. The problem with reading other's impressions, unless you have the off switch to forget it, is that they do influence you. Either your impressions start aligning with them or you force yourself to search for evidence against them. I am going to try and stay clear off that beaten track as far as possible.
I thought the only sane way to answer all his doubts would be to repeat something I did with mukulymn's RE-262 last year - only shaking off all the mvw2 influence which I was under at that time and doing something more my style these days - write a long, long review so that everybody falls asleep in the middle of it. Of course, if you are a brave soul who made it through this wall of text and what's to follow, pat yourself on the back and wish yourself luck, may be pray! You're gonna need it!
Buying EPH-100:
Yamaha EPH-100 is the current flagship IEM of the company. It can be bought from AudioAffair, UK for 73.74 GBP (~ Rs. 6600-6700 via Paypal) with normal trackable Royal Airmail or ~110 GBP (close to 10K) with FedEx shipping. At that price range, it competes against the likes of JVC FXT90, Sony EX-600.
External Factors
Build Quality: I like the housing design. It is well constructed of aluminum, thinner in diameter with a straight barrel form factor. Cable does not beg for attention. Strain reliefs look good. Left and Right markings in the housing - ah! someone at least 'gets' the whole point of it and not hide it somewhere else.
Accessories: Good pack of accessories with five sizes of bi-flanges, which look slightly different from the regular bi-flanges as they are more straight than conical. I think that is why I get a far better seal than with most bi-flanges. It also includes a 6.3mm adapater, extension cable and a case. The soft carry case reminds me a little of the Etymotic zipper case (but no brand name in this case), but is larger with good storage space for the tips.
Microphonics: Mild and bearable when worn down. Disappears when over the ear. I always prefer over the ear style wearing.
Isolation: Very good. I would say that this is among the better isolating ones I've heard of late.
Comfort: Comfortable for long hours.
Specifications:
Driver Type: Dynamic, Closed
Driver Unit: 6 mm (1/4â€)
Impedance: 16 ohms
Sound Pressure Level: 104 dB ±3 dB
Frequency Response: 20 Hz – 20 kHz
Weight (with Cable): 13.5 g (0.46 oz)
Cable Length: 1.2 m (47-1/4â€)
Connectors: 3.5 mm (1/8â€) L-type mini stereo, 6.3 mm (1/4â€) stereo
Sound
First Impressions:
Took too much time to unpack
I have Rockboxed Clip+ on shuffle for the whole media library at -33dB. I used the UE compatible single flange for a while before settling on the now dry stock bi-flanges. My first impression was that EPH-100 was nothing special. But then, I found no glaring faults either. Bass - check, Mids - check, Treble - Check, Sound stage - Check, Imaging - Check. So, how the hell does it sound, you ask? Very good.
At first, with the 'UE' tips, I thought 'heh! looks like we got ourselves a musical GR07. Does nothing much wrong, but not overly impressive'. With the stock bi-flanges, it sounds impressive.
The bass has good extension, impact, texture and quantity. To my ears, the quantity sounds just about right - it is north of anything bass light, but not as much as to get the tag "bass heavy", leave alone "bass head" IEM. The mid-bass has the mild upper hand while the sub-bass has enough grunt when needed. The texture is good, but does not feel filled in to the point where I'd call them 'fuller sounding' like the DDMs of the world. the decay is a tad on the slower side. When needed, the bass steps in with the punch, but not going to the extent of being omnipresent and annoying on every track. It is clear, but does not portray all the minor details.
The mid range is neither forward nor recessed - somewhat centered with a slight presence of warmth. In the same manner, it is neither thick nor thin. It manages to avoid irritating peaks, stays clear of sibilance and has a smooth, somewhat fluid character to it.
The treble continues along the path set by bass and mids by staying smooth and easy on the ears. It is neither too rolled off to annoy me nor does it worry the treble-phobic with an aggressive presentation. In contrast to the mids, the treble is slightly thinner sounding.
The sound stage has good width and decent depth. So far, with most music, I found it to have good separation, imaging and layering.
It feels like someone carefully drew a Lakshman Rekha for every aspect of it's sound on both sides ('lacking' vs 'too much') like a railway track to run on. But the most important derivative of this tuning is that it sounds very smooth and engaging. It is not an IEM you would want for hearing the most intricate of details or get an adrenaline rush from the music, because I don't feel it's snappy or energetic. It feels more like an IEM you would want to use for hours of listening because of it's smooth and laid-back nature. Isolation and comfort also come in handy enabling you to do just that. Most IEMs usually fall short in one aspect or another, but EPH-100 ticks all the right boxes for it's intended signature. It doesn't do anything incredibly special, but it is far from annoying me in any of the aspects.
Comparisons : See Post #3
Measurements by Rin : http://rinchoi.blogspot.in/2012/07/yamaha-eph-100.html
Conclusion:
To describe EPH-100, I will have to go back to what I mentioned in the beginning of this review. EPH-100 is truly a jack of all trades. Most IEMs usually miss out on one factor or another. But, EPH-100 combines comfort, isolation, good build quality and leaves nothing much to be desired in the signature. The good thing about their sound is that it stays clear of glaring faults and minor irritants that are usually a 'turn off' for listeners. On the other hand, it does not prove itself to be 'special'. I do not regard it to be on par with the IEMs I hold dear (EX-1000 and the like), but I do consider it to be a very safe recommendation for most upgrading from under Rs. 5000 price range.
Buying EPH-100:
External Factors
Specifications:
Impedance: 16 ohms
Sound
First Impressions:
Conclusion:
