Valid until May 20.
Selling it at ₹100 off. (₹1400)
Works only in the Shop App.
Most probably needs my mobile number to place the order.
Got it because Samsung decided to mess up my order.
Will post screenshots in a while.
Cheers.
Not required
You can see this is as custom as it gets
A few points to note -
- Order can be placed only from my account.
- Works only on the shop app/normal website. No corporate/student portal.
- Only online usage is possible. In-store won’t work.
- AFAIK, multiple coupons can’t be applied for the same Order, though I maybe wrong and am willing to try.
I’m selling this because to me, it’s an absolute waste and will probably expire before I find a valid use-case for it.
Attaching one more image showing my username. This is to comply with the forum guidelines. The same email is shown there but in print mode.
Cheers.
Update - Price reduced to ₹1000.
I have taken the voucher. Thanks @@badwhitevision
Feedback added.
Feedback exchanged. Was a pleasure @DEVRAJ BARIA
Mods please close the thread.
@puns
system
Closed
6
