hi bud i installed Ubuntu 5.04 hoary-rc-amd64 and it’s gonna be headache a little configuring after using Redhat/Fedora for so many years but no problem i like headaches
Now tell me whats ur problem on Ubuntu if any so i may tryto help you.
One thing i noticed Ubuntu does not allow root login in GUI bcoz it is disabled by default and you have to use SUDO. The first accouunt you create is SUDO. So you have to provide the password of this user while configuring for example Network etc.
One way to create a root password you will have to boot in Recovery mode. Note you get 4 options in Grub Menu when boot. Just select Recovery Mode.
Then just give command:[quote]
passwd
[/quote]
to create root pasword.
The second easy quick way is:
Now boot normally and login as the user you created. Now to execute root commands open terminal:
Hi m8 I have the Warty version 4.10 and have installed the x-86 version. The prob is I enabled the root account, but I cant play Mp3’s, cant mount Windows, cant Install XMMS.
Repositories are FTP servers at which the packages for your distro are present. Try following the steps to add extra repostores and then try apt-get. Also make sure your internet connection is active.
If you want to install XMMS from source, you will need to install the packages gcc (most important), automake, g++, binutils from the Ubuntu cd, or use apt-get to install them.
About the windows hard drive, are you sure it was hddb? Maybe Ubuntu uses a different type of dev filesystem, but in general, hard disks are labelled like this
hda for the first hard drive
hda1 for the first primary partition on the hda
hda2 for the second
hda5 for the first logical partition
hdb for the second hard drive
And so on … if you installed windows on you first HD, before installing anything else, the C drive would probably be hda1.
yes you are absolutely right. Newbies don’t know these security issues with IRC as root
Newbies are willing to learn and take an effort to understand concepts and i always help them
n00bs are dumb @#$%^&! who have no brains and keep shouting for help when the answer is there in front of them f888ing lamers and I hate n00bs > /dev/h3LL
