Advice: Switch Between PC & DJ Controller to MR4 Speakers
Hi everyone,
I’m looking for some advice on the cleanest and most practical way to route my audio setup.
Current Gear:
  • DJ Controller: Hercules Inpulse 300 MK2 (RCA Master Out)
  • PC: Can output audio via USB (A/C) or 3.5mm AUX
  • Speakers: Edifier MR4 (Active monitors, preferably using RCA input)
What I Want To Do:
  • Connect both my PC and my DJ controller
  • Be able to switch between them (no need to mix simultaneously)
  • Output to the Edifier MR4 via RCA
  • Preserve audio quality as much as possible
  • Budget: Under ₹10,000
  • Note: My DJ controller is connected to my laptop, and all laptop audio is routed through the controller. My PC is a separate source.
What I’m Considering:
  • A simple RCA switcher
  • A small line mixer
  • A USB audio interface with line inputs
  • Something like a small desktop preamp / monitor controller
I don’t need power amplification since the MR4 are active speakers.
Main goal:
Clean signal path + easy switching + minimal noise + good audio quality.
What would be the most sensible device type for this setup?
Would a passive switcher be enough, or should I look at a small mixer/interface?
Appreciate any recommendations :raising_hands:
A simple RCA switch. This should do.
4 In 1 Out 3.5mm + RCA Audio Switcher 4 Channels Audio Converter(Black)
