Yes available
Quantity?
Yes available
Quantity?
Flash OpenWrt on UniFi UAP-AC-LR | Step-by-Step 2026 Guide by our youtuber @Safcr7
Nice video , great part is performance is similar to stock ,but with additional features and options that open up with openwrt and I think it requires firmware downgrade if already on latest one.
My query, why is speed stuck on 300Mbps , when I am doing speed test on my mobile connected from Router to AP , it goes to 500Mbps . Test using WiFiman
It’s rated 700Mbps . @Safcr7 has 1Gbps connection. He’s standing right next to Router & AP
What version do you recommend I will try that and test.
Yes enough I have AC lite on my Home running UDM Pro.
When you use custom firmware, you dont get the same drivers on the router/AP that the OEM has. So hardware acceleration is missing generally.
They generally dont add it as it invites litigation.
Thats why transfer speeds are low even when in range. Check if the OEM hardware acceleration is available via some trick.
Not sure maybe we can enable through some tweaks and that may help.
An update was due
My guy has not been able to find the backplates . I have backplates for older orders only . Waiting for 2 more days as per him . Quantity as desired by everyone is availble but backplates….
Please wait for a couple of more days
They can be 3d printed. Not sure how durable they’ll be => UniFi AP AC LR by ToanN | Download free STL model | Printables.com
Maybe you can get these printed in bulk and save on shipping.
Will check it out
I’m not using any of mine, I didn’t even know they were included haha, I almost threw them out.
If you want, I can send them back to you to distribute to other members.
Will confirm, might take it & send you 3D printed ones so that you also have something.
Let my guy confirm first
Had sent to all except 1 member whom I forgot
2 buyers are without plates for whom I have got them but balance is waiting game for 2/3 day’s
Alright, I can always 3D print my own if I need it later, so they’ll be better off in your possession.
Thanks, keep them for me
Update same
No backplates , waiting
Update - 14 Jan
My guy can’t find the back Plates & not ready to reduce prices. I was wanting atleast 100-150/ bucks discount for them
3D printed back plates are being provided
Will that be fine or not ?
Update on 17 Jan
Hes not agreed to reduce . I will get them and send everyone a 3D backplate .
Next week everone should get them.
This video is and will be sent to all buyers which shows front pic of AP + MAC of the AP which you will get + Speed test
