Best Practices For Programming In C
Being An Expert Isn’t Enough, U Need To Present UrSelf Well… :smiling_face_with_sunglasses:
And When It Comes To Programming, You Should Know How To Write Ur Code Properly,:wink:
Yo,
Currently down.
Huh… Its’ Still Workin’ Here…
Try This…
Yep,
now both the links are working.
Presentation of your code, if required is important.
Else you should make it as complicated to the other person as possible so that he cannot understand it and steal it.
Make your own codes.
Code in your own codes.
@ Avtar,
Highlight my sig to reveal something :face_with_tongue:
That’s a good one mate. :slight_smile:
