BitComet is a p2p file-sharing freeware fully compatible with Bittorrent, which is one of the most popular p2p protocol designed for high-speed distribution of 100MB or GB sized files. BitComet is a powerful, clean, fast, and easy-to-use bittorrent client. It supports simultaneous downloads, download queue, selected downloads in torrent package, fast-resume, chatting, disk cache, speed limits, port mapping, proxy, ip-filter, etc.Clean and free, without any adware or spyware.
v0.58 2005.5.6
GUI Improved: add Hash-check thread priority as an option
GUI Improved: add “Remove task only” confirmation
GUI Bugfix: disable file location change for paused tasks
GUI Bugfix: can not auto shutdown computer when desktop is locked
GUI Bugfix: the auto-stopped task can not upload
GUI Bugfix: fix the win98/me auto shutdown issue
GUI Bugfix: fix the dde regarding file association
Core Improved: add task option: peer info exchange enable
Core Bugfix: UDP tracker DNS resolve can cause stop response for 2s
Core Bugfix: fix the issue when one UDP tracker in a tracker group can not connect
Core Bugfix: continue download at startup can not work if crashed last time
Core Bugfix: fix one crash issue when connections are unstable
