[Brand New] Cooler Master Addressable RGB LED controller - compatible with all MoBo
Compatible with MSI, Gigabyte, Asus, Asrock mobos proprietary RGB software
If mobo doesn’t have RGB (12 V) / A-RGB (5 V) connectors then you can connect your cabinet reset switch to it and use the built-in presets
Can connect 4 A-RGB (4-1 pin) devices directly and connect even more if you use A-RGB splitter
Also, it has a temperature sensor that can change the color theme of your A-RGB devices to reflect your system temps
I ordered one from amazon but I did not as the A-RGB presets through my mobo or the device itself. My cabinet has an A-RGB controller within which I feel has better A-RGB presets.
So I placed a request for a return but only replacement was available. I got a new piece which I opened up to check if all wires are there and to take a pic to post here. It is brand new and unused.
Hi, I’m interested. Can we. Take it to PM?
@@FreakyChokra - Sure!
Price reduced to 1600/-
Looking for a quick sale
Is this similar to Commander?
not sure about commander.. but this is one is supposed to take inputs from your mobos 5V (4-1 pin) or 12 V (4 pin) header and then act as a ARGB hub.. so basically you can would be able to control your ARGB stuff from your mobo software
Amazon.in: Buy Cooler Master Addressable RGB (ARGB) Controller Online at Low Prices in India | Cooler Master Reviews & Ratings
Thanks for the informative reply but I am sorry, I thought it is similar to Commander
Interested. I’m Bangalore based, so perhaps we can talk on Whatsapp? Will PM.
Payment received. Item shipped.
Mods, please close the thread.
Controller received. All items in package. Thanks!
